Hello all, it's been a while.
I have a 2004 V6 with 162k miles on it and about week and half ago CEL and VSC lights came on. I noticed a slight rough idle. Plug in my OBD II scanner and it was reading P0016 Camshaft Position A - Camshaft Position Correlation (Bank 1). Based on some reading on here I was thinking it was a stretched timing chain so I didn't drive it until I could get it into the shop.
Just had in the shop (local independent shop I trust) and they did a diagnostic and said the following "Check Engine, found P0016 - Crank/Cam Position Correlation B1 S "A". Check circuit, bank 1 VVT solenoid will not command from PCM, VVT solenoid checks good, not getting signal from PCM".
I talked to mechanic and he thinks its something electrical related and recommended have dealership take a look at it
Since Thursday, I cleared the code. Friday CEL and VSC lights came back on. Ran the scanner and got P0010, P0012, P0074 (no more P0016).
P0010: “A” Camshaft Position Actuator Circuit Bank 1
P0012 - Camshaft Position 'A' Timing Over-Retarded Bank 1
P0174 - Fuel Trim System Lean → Bank 2
I cleared all these codes. And today P0012 came back but no other codes. Cleared codes again and CEL/WSC came back on again and read P0012. Truck seems to running fine otherwise.
I’ve read a lot of the other post on here regarding P0012 and the other codes. I plan to get the oil changed this week however I have been getting regular oil changes every 5k. I know some people say to change out the OCV. I may try that as well if oil change doesn't fix it.
I also took off the cover on the front of the engine to take a look at the time chain tensioner. I am unsure of what to make of the picture as I do not know what it is supposed to look like.
Any advise on how to troubleshoot or different things to try? I can take it to the dealership but I know how that goes and would prefer to figure it out on my own if possible.
Thanks in advance,
2004 Sport Titanium Metallic, Black WeatherTech Mats,
J.A.'s Map Light Mod, 2014 Scion Pioneer Bespoke touchscreen w/ Back Up Camera, Arc Audio xdi805 amp, Handsfree phone/bluetooth steering wheel controls, 06-09 OEM LED tail lights, Interior LED Swap, Gentex 177 AutoDimming Mirror w/ Amber Compass,
Sunvisor GPS mod, Avitol 4003 Remote Start w/ factory keyfob,
J.A.'s DRL Mod,
Back Window Up Hack,
OEM 115v AC inverter install, Smokers Kit
