Old 09-20-2020, 12:17 PM #1
knightsfs4's Avatar
knightsfs4 knightsfs4 is offline
knightsfs4 is an unknown quantity at this point
knightsfs4's Avatar
Rear Sub Removal, Cutting The Plastic Grill?
Feels good to be back, first post in quite some time!
I am going to be installing a new rear sub soon. I saw this on Youtube, and wanted to see if anyone else had done the same thing? I personally don't like cutting factory plastic, but honestly this just seems so easy...
4th Gen Toyota 4Runner JBL subwoofer replacement- the easy way. - YouTube
I'm on the fence. Tell me why I am dumb, or not
Knightsfs4 Build Thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
Jack-Purchased on 11/22/10- 2006 Limited 4X4 V8
knightsfs4 is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 10:27 PM #2
Sean7 Sean7 is offline
Sean7 is on a distinguished road
I replaced my sub with the same one he is using and used his video for quick instructions. However, I chose not to cut the plastic grill and opted to do it the right way and take the whole panel off.
I understand why some people would want to cut it. But overall the whole job did not take me that long, less than an hour to do. If it was something that I had to deal with every month or couple month, I would consider cutting it. But since it's something you don't have to change often, I would just do it the right way and take the whole panel off. Just my opinion.
Sean7 is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 10:34 PM #3
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
I also considered cutting it, but opted not to. It doesn't take long to replace plus you have better access by taking it all apart. I used this video for reference 2003 - 2009 Toyota 4Runner OEM Subwoofer Install / Replacement - YouTube
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 12:10 AM #4
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I also removed everything when I replaced my factory sub. It wasn’t very hard to do, and I didn’t break anything.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 10:22 AM #5
Drak's Avatar
Drak Drak is offline
Real Name: Doug
Drak is on a distinguished road
Drak's Avatar
Real Name: Doug
I wouldn't have a problem just cutting out the grille if that's what you wanted to do.
He recommended CYA glue to re-install the grille which I would Not do.
I would find a more suitable adhesive myself...
I see CYA glue on a vertical surface as turning into a mess rather quickly.
But if you're hesitant simply because it's going into an unknown, I'll clear that up for you.
There are 5 screws to remove, then the rest pops off.
Two are 10mm hex head bolts from the top down in those little cubbyholes.
One is a 14mm bolt for the seat belt.
Then you have to pull the carpet back a few inches to expose two phillips head screws holding it to the floor.
If you look at my pic up close, you'll see two white square plastic pieces right in front of the wheel well on the floor.
Those are where the phillips head screws are located and they are under the carpet, which is why you have to pull the carpet away to get to them.
Then, the rest pops out.
The only difficulty, really, when re-installing, is the white plastic insert at the very front nose, in front of the seat belt bolt hole.
That's a bit difficult to get back in place with the seats already installed.
But not impossible, just slightly more difficult.
2003 Imperial Jade 4Runner Sport Ed.
Drak is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 01:51 PM #6
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
No matter the method, replacing the sub is very worthwhile. Mine was completely blown. You can see the tearing on the right side. I didn’t even replace it with something high-end. That’s an older Pioneer and it sounds great off of the factory amp.
Old 09-21-2020, 03:16 PM #7
Drak's Avatar
Real Name: Doug
Drak's Avatar
Real Name: Doug
I certainly concur with that .
Mine had no surround left nearly at all when I removed it.
I decided to upgrade to a 10" sub and re-purpose the JBL box for the new crossovers and amp.
cutting , personally , plastic , rear , thing
Removal of the rear cargo area plastic interior pieces alia176 4th Gen T4Rs 14 05-31-2019 11:52 PM
Cutting Grill for Lights SteadFAST 4Runner 5th gen T4Rs 1 12-22-2017 12:34 AM
Plastic removal around rear wiper gundrted+t4r 5th gen T4Rs 1 04-07-2017 02:57 PM
Ditch pillar light mount w/o cutting plastic? 5th gen smakdatt 5th gen T4Rs 8 07-23-2016 08:15 AM
plastic chrome grill to black bare plastic saftly T24TODD 4th Gen T4Rs 10 01-27-2011 12:52 PM
