Old 04-10-2011, 09:06 PM #1
jbmccul's Avatar
jbmccul jbmccul is offline
jbmccul is on a distinguished road
jbmccul's Avatar
Best Aftermarket Trailer Hitch?
I've got a 07 SE V6 that didn't come with the trailer hitch. Was wondering what different kinds you all have on your runners. After searching the forum the Curt hitch was popping up alot but I've heard it can need some cutting to install. I will mostly be using the hitch for a bike rack but also as a recovery point.
jbmccul is offline   Reply With QuoteReply With Quote
Old 04-10-2011, 09:36 PM #2
Burt Burt is offline
Burt is on a distinguished road
I put the Curt on my '08 SR5 and it was super easy to do. Not sure what cutting you are referring to. The hitch comes with 4 bolt to attach to frame.
Will take about 1/2hour to install.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 04-10-2011, 09:38 PM #3
jbmccul's Avatar
jbmccul's Avatar
Thanks, i was hearing that it pushed in the underside of the rear bumper so some people did some trimming. Has the clearance with the bumper been an issue?
Old 04-10-2011, 10:38 PM #4
No trimming required on my rear bumper. Tightning the bots on to frame just above the resonator is the most challenging task. There is only a couple inches of clearance. I wonder if others were referring to mounting on a 5th gen?
Burt
2008 SR5 V6 4WD
2019 F250 SuperDuty
Old 04-11-2011, 07:50 AM #5
TOYLUVA's Avatar
TOYLUVA TOYLUVA is offline
TOYLUVA is on a distinguished road
TOYLUVA's Avatar
If its like mine It has no factory cutout for the hitch. the rear rollpan is solid across the bottom. It would need to be notched to install a factory hitch. Not sure about the Curt.
07 Sport ,titanium ,XREAS, DS 2.5/1.5,tint, ventshades, 265/70/17 terra graps, gutter guard grill, hydrocabon filter removed, VSV insulated. husky liners. K&N Air. Curt 13445 hitch.
TOYLUVA is offline   Reply With QuoteReply With Quote
Old 04-11-2011, 05:57 PM #6
The Curt I was referring to is the Weight Distribution hitch, has a solid pipe like receiver across the rear and below the body.
Trailer Hitch for 2008 Toyota 4Runner - Curt 13445
Burt
2008 SR5 V6 4WD
2019 F250 SuperDuty
Old 04-11-2011, 07:27 PM #7
Doozi's Avatar
Doozi Doozi is offline
Doozi will become famous soon enough
Doozi's Avatar
I just installed that hitch on mine a few weeks ago. It does touch the bumper cover just slightly... just enough to see it flex a tiny bit when you tighten the receiver's bolts. I ended up having to take mine back off in order to get the wiring harness bracket off so that I could modify it. You can't open the lid in the stock position. While I had it off I trimmed about 1/2" off of the bottom of the center bumper detail... very easy with an X-acto blade. No details on the trimming, but it wasn't really even necessary.
A little more "Utility" for my SUV!
~Doozi
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
Doozi is offline   Reply With QuoteReply With Quote
Old 04-11-2011, 08:59 PM #8
jbmccul's Avatar
jbmccul's Avatar
Thanks Doozi, I looked at your thread, do you have any pictures of the mount locations under the truck? Also, how long did it take you to install?
Old 04-11-2011, 10:22 PM #9
Doozi's Avatar
Doozi's Avatar
I'll go take some pics... mounting points, the modified wiring bracket, and I'll see if I can get a shot of the little piece I trimmed off of the bumper. Stay tuned...
Old 04-11-2011, 10:29 PM #10
jbmccul's Avatar
jbmccul's Avatar
Sweet, thanks!
Old 04-11-2011, 11:17 PM #11
Doozi's Avatar
Doozi's Avatar
OK... I'm trying this completely from my iPhone so I hope that the pictures are oriented properly.
Driver-side mounting bolts
Exhaust hanger near resonator... just pry the bottom off of the post with a large screwdriver
Passenger-side mounting bolts from directly below (showing the exhaust interference)... with a long socket extension you can get up there easily as the unhooked exhaust can be pulled out of the way
Modified wiring bracket... I cut the ribs with a Dremel and then hammered the bracket flatter so the plug is more vertical and allows the cover to swing open (this has to be taken off before the receiver gets mounted). I primed and painted it after I cut and bent it to prevent rust
Hard to see without dropping the spare, but right behind the spare you can see the notch I cut out of the bumper... It was only across the center square detail (3 total on the bumper)
Hope that helps! And when you go to install the bumper, you get set the passenger-side of the receiver up on top of the exhaust and focus on getting the driver-side bolts started.
Good luck!
Old 04-11-2011, 11:23 PM #12
Doozi's Avatar
Doozi's Avatar
BTW, it only took me about 30 minutes to install, but then I had to take it back off a week later to modify that wiring bracket! Didn't even think about that little plug hatch not being able to open far enough!
Old 04-11-2011, 11:30 PM #13
jbmccul's Avatar
jbmccul's Avatar
Thanks man, it helped alot, but you said something about installing the bumper?? Did you have to take it off?
Old 04-11-2011, 11:32 PM #14
Doozi's Avatar
Doozi's Avatar
Sorry! Not bumper... Receiver! I didn't even have to drop the spare!
Old 04-12-2011, 10:10 AM #15
jbmccul's Avatar
jbmccul's Avatar
Awesome, how much did your hitch run you, I've seen them anywhere from 175-300 on the net.
Which trailer hitch wrpsuite 3rd gen T4Rs 12 06-10-2010 01:57 PM
Trailer Hitch FoozGrind 4th Gen T4Rs 13 03-07-2009 09:18 AM
Trailer Hitch FoozGrind 4th Gen T4Rs 11 08-26-2008 11:12 PM
Where to buy a trailer hitch? Mtneer001 Engines / Suspension / Wheels / Tires / Audio / Accessories 7 06-18-2007 03:24 PM
Trailer Hitch smccollamjr 3rd gen T4Rs 1 09-24-2005 08:04 PM
