Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 09-21-2020, 11:22 PM #1
Rannd's Avatar
Rannd Rannd is offline
Member
Rannd is on a distinguished road
Member
Rannd's Avatar
V8 rough idling issues, anyone help? - P0300, P0303, P0305
Hey everyone, I’ve spent so much money and have had so many headaches fixing the exhaust on my 4Runner. So much money spent for parts and labor. Was getting codes for not having cats and all of a sudden my air pumps started turning on at startup. So I bought the URD rear sensor simulator and a air pump delete kit for a local shop to install. They installed them and it ran great but then I got P2241 and P2A00 codes which I believe are 02 sensor codes. Do I just need to replace all the 02 sensors or do I not need to? One thing I immediately regret is going catless. It smells so bad... cars I’ve owned in the past that went catless never smelled this bad.
Mods:
Doug Thorley long tube headers (no cats)
URD off road Y pipe
URD muffler
__________________
2007 Toyota 4Runner Limited - My Build Thread
Rannd is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 12:48 AM #2
Rannd's Avatar
Member
Member
Rannd's Avatar
Anyone help at all?
__________________
Old 09-24-2020, 02:56 PM #3
Zero0575's Avatar
Zero0575 Zero0575 is offline
Member
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Member
Zero0575's Avatar
Real Name: Casey
Quote:
Originally Posted by Rannd View Post
Anyone help at all?
You didn't happen to install spacers on the front O2 sensors did you? Those codes are for low voltage on bank 1 sensor 1 and bank 2 sensor 1, both of the pre-cat / AF sensors. If you install spacers, they're supposed to go on the post cat sensors.
Aside from that, just make sure the pre-cat sensors are plugged in. Doesn't make sense that they would both just randomly go bad at the same time.
__________________
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 11-07-2020, 11:56 AM #4
Rannd's Avatar
Member
Member
Rannd's Avatar
So I took it back into the shop, they were able to clear the codes and drove it three times and didn't see codes.
They told me they contacted URD and they had to adjust settings on the URD Rear Sensor Simulator.
Here are the shop notes:
Multiple miss fire codes present. Voltage issues in system for PCM/ ECM / 02 Sensor values not in spec. Customer has aftermarket exhaust , 02 sensor foulers, trick box to prevent issue. Worked with exhaust manufacturer to verify specs. Original specs from install of value box needed to be raised slightly. Told to move slightly increase as light arrives. Testing procedure is drive vehicle at temp to 75 mph and quickly let off gas pedal. This engages testing procedure. Last test drive technician did this test 3 times with no light returning.
I drove the 4Runner 2 times after I got it back and now I'm getting codes P0300, P0303, P0305. Still runs like crap when it idles... drives fine when on the highway.
__________________
Old 11-07-2020, 05:52 PM #5
importman importman is offline
Member
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Member
Real Name: Danny
With the fact that you have misfire codes on adjacent cylinders and it only runs poorly at idle I'd want to look for a vacuum leak in that area. I'm not familiar with that air pump bypass but I wonder if they left a hose unhooked or something.
__________________
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 04:23 PM #6
Rannd's Avatar
Member
Member
Rannd's Avatar
Had the shop remove the cat delete spacers, drove down to Florida and back with no codes and engine idling fine, woohoo!
__________________
Reply
Tags
bad , catless , codes , sensor , urd
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Some Sensor issues Mattkrane9090 Classic T4Rs 0 11-07-2019 06:12 PM
Knock sensor issues Jt2El46 3rd gen T4Rs 1 05-19-2017 05:33 AM
Tell me where to stick it! My aftermarket Transmission Sensor that is... bass-o-matic 3rd gen T4Rs 15 11-13-2014 11:13 PM
2000 4Runner - A/F Sensor... O2 Sensor... California Exhaust but Federal ECU...Help! vandettaz 3rd gen T4Rs 0 03-16-2014 03:47 PM
95 V6 Knock sensor issues shotwell Classic T4Rs 2 07-27-2008 10:10 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
