Old 09-22-2020, 08:33 PM #1
4RunnerFundi 4RunnerFundi is offline
4RunnerFundi is on a distinguished road
Replacing Alternator now...cannot get the idler pulley bolt to budge... advice?
Title says it all, I'm sitting out in the mist and dark trying to replace alternator on my 2006 V6 4Runner and have removed battery and can not get the idler pulley bolt to budge so I can get tension off of the belt and of course remove the idler pulley also. If I recall the idler pulley bolt has loktite on it? Yes/No?
Any advice on turning the idler pulley bolt without rounding it off or damaging something? FYI I am not a very good mechanic, but I try... Thanks!
God Bless
4RunnerFundi is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 09:25 PM #2
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
You don’t need to remove any idler pulleys. Just loosen the tensioner to put some slack on the belt. You should be able to get all the bolts out just fine.
Just replaced my alternator about a month ago.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 11:10 PM #3
montijo505's Avatar
montijo505's Avatar
Also if I recall that bolt is reverse threaded, so you're likely tightening it.
Sent from my SM-G986U using Tapatalk
Old 09-23-2020, 04:57 PM #4
PedroV PedroV is offline
PedroV is on a distinguished road
God Bless
You do not need to remove the tension pulley wheel, just apply pressure like you are going to remove it, but when you do that, it will push the pulley wheel in against it's spring, which will release tension on the pulley, and allow you to remove the serpentine belt.
PedroV is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 05:24 PM #5
Berty_K's Avatar
Berty_K's Avatar
Heres a video that I found super helpful: Toyota FJ Cruiser - Alternator Replacement (and Diagnosis) 2007-2014 - YouTube
Old 09-24-2020, 01:06 AM #6
I got it out and new in.... buuuuut.... now when I attach the negative battery cable the alarm goes off honking and stays honking and even when I start up the vehicle it continues to honk and I have to remove the negative battery lead... ideas? This is driving me to drink
Old 09-24-2020, 10:55 AM #7
Berty_K's Avatar
Berty_K's Avatar
Have you checked the charge on your battery? Might be bad at this point
advice , alternator , bolt , idler , pulley
What size/pitch is the idler pulley bolt eds72 4th Gen T4Rs 1 03-16-2019 06:51 PM
Looking for advice on an alternator bolt jimmyw 4th Gen T4Rs 7 02-24-2019 09:36 AM
Idler pulley 4runner_kid Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-17-2011 09:24 PM
Replacing idler pulley: toy4runn2004 4th Gen T4Rs 1 08-30-2010 09:12 PM
5VZ 3.4L AC idler pulley raydouble 3rd gen T4Rs 0 01-03-2010 06:59 PM
