Old 09-25-2020, 12:49 PM #1
Lolaya Lolaya is offline
Lolaya is on a distinguished road
Radiator Reservoir found empty (138k miles)
Hi everyone,
I have a 2005 4th gen V6 4runner with 138k miles.
I got a synthetic oil change at dealer and they let me know that the radiator reservoir for the coolant was empty. They filled it up and told me the radiator needs to be replaced. Quoted at $591 which doesnt seem terrible but you all might know better.
What Im wondering is if the dealer is trying to rob me by saying the radiator needs to be replaced, and then coming out later saying the hoses need to be replaced as well after the fact.
How can I check to see if the reservoir is empty again to see how fast/slow this leak is?
Thank you,
Lolaya
Lolaya is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 01:10 PM #2
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
It's very easy to check the radiator/coolant reservoir. Behind the radiator on the passenger side is a white, semi-transparent plastic container. That is the reservoir. It has a black tube coming out from the top that goes to the top of the radiator. Looking at the side of the reservoir, you will see marks showing the fill levels. The coolant is a red color and can easily be seen. If you cannot see any coolant, then it's empty.
techno is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 01:41 PM #3
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
I'd verify the leaky radiator first. You'll be able to see pink fluid or crust at the site of the leak. You can also ask the shop that diagnosed it to point out the leaky part.
Your fluid either leaked out, boiled out during an overheating event, went into the transmission, or went into a cylinder through a faulty head gasket. Hope that it's a leaky radiator or hose.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 02:08 PM #4
stay away from the dealership unless your vehicle is under warranty! they charge a lot more for any service than a reputable mechanic/shop will charge. find a local shop to diagnose the radiator/hoses, ask friends or family where they go or pick a bigger name shop like goodyear or midas etc.
the radiator itself is a $100 part & takes all of about 1-2 hours to change out, no way does it cost $600 to change a radiator.
as mentioned, just monitor the overfill reservoir, its easy to see the fluid level. & look under the vehicle to see if you see any wet spots or drops on the ground.
Old 09-25-2020, 02:08 PM #5
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
You should see something like this on the radiator. You can buy a denso radiator for $100 shipped from rockauto.com and some new radiator hoses for around $25/pair. Coolant will be about $25 gallon and you need 3 gallons. For $200 you can do it yourself and save $400.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 03:14 PM #6
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
My dealer told me I needed a radiator 4 years ago. Still have same radiator and NO problems. Do some checks as advised here and then decide.
Old 09-25-2020, 03:36 PM #7
Urbanite Urbanite is offline
Urbanite is on a distinguished road
Originally Posted by Lolaya View Post
Hi everyone,
Thank you,
Lolaya
That's why they're called the, "Stealers!"
Urbanite is offline   Reply With QuoteReply With Quote
Old 09-26-2020, 08:42 AM #8
blee1099 blee1099 is offline
blee1099 is on a distinguished road
Go to a local parts store and rent a radiator pressure tester and run a pressure test on the radiator. Pump it to about 15psi and see if you have any loss of pressure. If it can maintain pressure for 5-10 minutes I'd say you're good.
blee1099 is offline   Reply With QuoteReply With Quote
Old 09-26-2020, 11:26 PM #9
Thanks man. I checked yesterday when engine was cold and it was full. So now I know its not a large leak if any continuous leak at all.
Should I now wait to see the level when its hot?
Im a little worried it could be my head gasket. Any other warning signs for head gasket since I know this 4runner can have issues with that eventually.
Old 09-27-2020, 12:17 AM #10
Im pretty sure I didnt have an overheating event because I am always looking at my temperature gauge and have never noticed any vapor/smoke coming from front. Any other signs for overheating/faulty head gasket?
Old 09-27-2020, 07:08 AM #11
Captsolo Captsolo is offline
Captsolo will become famous soon enough
OEM radiator takes an hour to install and costs $100.
Don't let your SR5 overheat. Is it leaking? Can you see coolant on the ground?
Amazon.com: Denso 221-3117 Radiator: Automotive
My 2005 4runner with 150,000 miles has never had a coolant or radiator or overheat issue - even once in 15 years.
Captsolo is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 10:32 AM #12
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
There are other places besides the radiator or hose that could be the source of a coolant leak. My '04 4runner developed leaks at the outlet gasket behind the thermostat. Look around behind the thermostat housing for any tell tale signs of a reddish crusty build up.
Hunter61 is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 05:22 PM #13
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Be sure to check the radiator cap as well. Mine was losing a small amount of coolant and I couldn't find it. Checked and the rubber was worn on the cap. New cap - problem gone. (Make sure the engine's cool when you remove the cap)
importman is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 11:46 AM #14
techno's Avatar
techno's Avatar
Don't worry about the hot vs cold level yet. Just watch either (I'd watch the cold) over the next few weeks to see if it noticeably drops.
I'd watch for all the classic warning signs and symptoms for head gasket.
I had two sources of coolant leak on mine. The water pump and some pin holes in the radiator.
Old 09-29-2020, 06:04 PM #15
oldboy's Avatar
oldboy oldboy is offline
Real Name: Lou
oldboy is on a distinguished road
oldboy's Avatar
Real Name: Lou
This bad radiator cap happened to my son as well a few of years ago. 1997 Camry losing coolant and overheating. I towed him in for a repair. Mechanic replaced radiator cap and car has been running great ever since. I now replace radiator caps on my cars when they are 10 years old. Cheap insurance at less than $10.
04 V8 Limited, gray one
oldboy is offline   Reply With QuoteReply With Quote
dealer , empty , radiator , replaced , reservoir
V6 Gates Serpentine Belt after 138K Miles lightfreak 4th Gen T4Rs 8 05-12-2022 08:10 AM
Coolant: Rad is full, reservoir empty. Wut? zazzomicron 3rd gen T4Rs 16 11-25-2019 10:47 PM
PO116 - Coolant Reservoir Empty NEKExplorer 3rd gen T4Rs 9 08-28-2017 12:36 AM
FS: 2002 3rd Gen 4Runner, 138K miles, Thundercloud Metallic, Denver CO, $11k obo KentuckyChunder For Sale: Vehicles 16 04-04-2015 05:09 PM
Radiator Reservoir Level mustangaustin34 3rd gen T4Rs 6 10-26-2014 07:42 PM
