Old 09-29-2020, 11:11 PM #16
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
See if there is a rubber hose is going from the plastic cap to the bottom of the inside of the white plastic reservoir. If that is gone, fluid cannot go in/out of the radiator as it heats up and cools off, eventually causing a low fluid level in the radiator.
gaber6 is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 01:56 PM #17
Lolaya Lolaya is offline
Lolaya is on a distinguished road
So I have the black plastic tube that goes in. My coolant is down again (not fully empty but near the bottom of the plastic reservoir.
Does that mean the tube wont be able to pull it up if it doesnt reach all the way to where the coolant is?
Lolaya is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 05:56 PM #18
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
If the tube isn't in contact/submerged with/in the coolant then it won't suck any coolant back into the radiator, you need to keep the coolant level up to the full line!
2004 Limited V8
Old 10-31-2020, 10:34 PM #19
So I definitely have a leak and it must be fairly big if it takes 2 weeks to drain it.
Where does the fluid go from the bottom of the reservoir?
Old 11-01-2020, 01:41 AM #20
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Does it stumble/misfire at startup?.
Any error codes?
If none, you could try swapping the radiator cover to a new one.
Or have a shop perform a compression test on the cylinders or a leak test on the radiator.
A cars cooling system has many point for potential leakage, you need to patiently go through them
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 10:17 AM #21
Get a hose that reaches the bottom for sure.
On a cold start, is there a sweet smell coming from the exhaust? A few drops of coolant is noticeable enough.
Old 11-01-2020, 12:48 PM #22
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Have you checked the waterpump, it can puke all over the front of the motor.
Can be hard to see from above, pull the front skid and look from below.
A black light or UV light will make our antifreeze glow bright pink, can help track down a leak.
Drop a couple pics in here someone may just be able see something you dont.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 02:09 PM #23
So I finally had time and good weather to look more closely at everything after learning a bit more about the different parts of the radiator.
Definitely found the leak (after spotting the wet spot on road).
Here are some pictures:
In the second photo, the black plastic tube on the right leaking is the coolant release valve right? Is that leaking too? Does that mean it should be replaced?
Old 11-01-2020, 04:27 PM #24
Real Name: Skip
Real Name: Skip
In your second photo the black plastic piece I see is one of the 2 side tanks on the radiator, on one of the side tanks there is a petcock/drain to drain the coolant from the radiator but it's not in your photos that I can see, all of the above are parts of the radiator, you just need to replace your radiator with a new one to correct the leaks in your photos, you can get a new Denso or Koyo radiator, both are of the highest quality and equal to OEM for about $100 plus the labor to install it.
I would as mentioned check the water pump as well, there is a small hole on the bottom of the shaft housing behind the cooling fan, that hole is where it would be leaking if it's bad,
2004 Limited V8
Old 11-01-2020, 05:31 PM #25
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
15 year old plastic radiator. Looks like your ready for a new one.
That petcock is just the drain for the radiator, has o-ring on it that could fail.
It would be on the back side of that 2nd pic.
AuSeeker said "soyo" think he ment KOYO...
Lol...is that a brain fart, like in made in china.
Thought i would mention too, that radiator i just replaced did not come with the 4 rubber mount bushings, you have to reuse the old ones.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 11-01-2020, 05:41 PM #26
Real Name: Skip
Real Name: Skip
Yes indeed it should be Koyo!
I corrected that in my post, Thanks!
I guess you could say it was a "brain fart" but at my age I call it CRS (Can't Remember $hit) LOL
2004 Limited V8
Old 11-02-2020, 06:37 PM #27
Thank you and everyone for their help. A new reputable mechanic im looking at is charging me $441 for radiator parts, labor, and coolant replace. Its a NAPA radiator with lifetime warranty.
Through costco I get a 15% discount. Comes out to ~375. Does this sound alright? Should I ask them to replace anything else? Coolant flush?
I have a gallon of the toyota super long life coolant Ill bring to them to use as I dont want them using any other one.
Old 11-02-2020, 07:04 PM #28
Real Name: Skip
Real Name: Skip
I can't say if that's too much or not, but to me since I do my own mechanical work it sounds a little high since I could buy the parts and do the work for under $150 including coolant, shouldn't take longer than 1 1/2 hours, I could do it in an hour.
That being said the V6 cooling system holds a little over 2 1/2 gallons of coolant, I don't think 1 gallon will be enough, you might want to get another gallon just in case.
2004 Limited V8
Old 11-02-2020, 07:25 PM #29
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
That price is good. I would have no hesitation paying that much if I didn't have tools and the know-how on how to replace such an important part.
No need to ask for a coolant flush. Most of the old stuff will drain out when the hoses are disconnected.
techno is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 08:48 PM #30
Captsolo Captsolo is offline
Captsolo will become famous soon enough
I check the overflow canister about once a week. Always right level in my 2005 4runner. Never had an overheat in 15 years.
Your radiator is definitely done.
NAPA radiator with lifetime guarantee is way to go. Get the receipt and keep it. NAPA will replace it if it ever fails.
2 gallons of coolant is enough. Zerex for Asian cars is pink. Amazon has it for $18 a gallon.
Hope you don’t have other issues. Overheats can ruin a V6 4.0.
I have same engine as you with 150,000 miles.
Thanks for the info on the NAPA radiator. That is a steal. I bought a starter with a lifetime warranty! Still have the box and the receipt. It's my third starter.
I'm on original WP (150,000 miles)
Life Expectancy of Water Pump? | Toyota Nation Forum
Toyota 4Runner Engine Water Pump. Main Engine Water Pump - 161006939883 | South Dade Toyota, Homestead FL
Captsolo is offline   Reply With QuoteReply With Quote
dealer , empty , radiator , replaced , reservoir
V6 Gates Serpentine Belt after 138K Miles lightfreak 4th Gen T4Rs 8 05-12-2022 08:10 AM
Coolant: Rad is full, reservoir empty. Wut? zazzomicron 3rd gen T4Rs 16 11-25-2019 10:47 PM
PO116 - Coolant Reservoir Empty NEKExplorer 3rd gen T4Rs 9 08-28-2017 12:36 AM
FS: 2002 3rd Gen 4Runner, 138K miles, Thundercloud Metallic, Denver CO, $11k obo KentuckyChunder For Sale: Vehicles 16 04-04-2015 05:09 PM
Radiator Reservoir Level mustangaustin34 3rd gen T4Rs 6 10-26-2014 07:42 PM
