Old 09-29-2020, 11:24 PM #16
payeentbawlur's Avatar
payeentbawlur payeentbawlur is offline
payeentbawlur is on a distinguished road
Originally Posted by firebirdguy View Post
another thing to mention about the KYB vs stock is they provide a bit of a lift in the front due to the new/stiffer springs. mine gained about 1-1.5" over the 145k but not sagging stock fronts, gave the 4runner an almost leveled stance.
i would not consider kyb "NOT" good, they arent the "best" but for the price they are hard to beat & are very good quality & ride. gotta compare allples to apples for things like this. if you do some research they get excellent reviews for any vehicle.
& any brand shock can fail depending on the use or manufacturer defects... kyb's lifetime warranty will replace a failed shock free of charge.
Originally Posted by LA4RUNNERGUY View Post
I just read through this post and the comment from firebirdguy caught my attention. That when installing the KYB's in the front will raise the front end, possibly leveling it out.
I have a leaking front shock and will need to replace it soon and planning to get the KYB's. I did not know this when I installed the Daystar 1" level kit about a month ago. The guy at the shop either didn't notice it or didn't see the need to tell me, or it happened after the fact. Not sure.
Should i remove the Daystar level kit when installing the KYB's since these may provide the front leveling I want? Or do the KYB's eventually settle and the front rake returns?
Thanks,
BEFORE KYB:
AFTER KYB:
So the before image is with a blown strut on the stock suspension with 200k miles.
The after is with the KYB shocks installed in the front and back. With the same rubber, different rims. No spacers, all suspension lift.
It resulted in a significant lift and level for the front. I didn't bother measuring unfortunately. But that can give you a bit of an example of what you may get on your rig.
payeentbawlur is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 12:03 PM #17
Thanks,
yes the kyb did add some lift to the front, mostly due to the 10% stiffer than stock new springs vs the 145k originals.
the lift from the KYB doesnt totally level the front but does raise it back to new height plus a little more. the pics above are a good estimate of the lift & here are a couple pics of mine (after & before) last year about 1000+ miles after the lift & it still looks & measures the same today so any settling is minimal & will happen in the first 500-1000 miles. same 265/70/17 tires & no other changes to suspension. stock rear springs.
if you want a true level i would suggest installing the kyb's without the front spacers to see how you like it after a couple months, then since its so easy to reinstall the spacers, do that if you want more lift.
KYB Excel-G or Bilstein?-20190817_172841a-jpg  KYB Excel-G or Bilstein?-20190512_151806a-jpg
Old 09-30-2020, 04:51 PM #18
LA4RUNNERGUY LA4RUNNERGUY is offline
Real Name: Marciano
LA4RUNNERGUY is on a distinguished road
Real Name: Marciano
Thanks to both for the responses. I will install the new KYB front struts and remove the 1" DS. do mind confirming if the KYB's you installed on the front are these? I want to be sure it's the same one I found on line?
Is it the KYB Strut Plus
SR4130 & SR4131
2009 Lexus Rx350
2022 4Runner Limited
LA4RUNNERGUY is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 07:06 PM #19
keithyota keithyota is offline
keithyota is on a distinguished road
UCA adjustable?
keithyota is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 07:15 PM #20
SR4130 & SR4131
That's the pair I'm running good sir. You've got it!
Old 09-30-2020, 09:48 PM #21
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
SR4130 & SR4131
YESSIR. I just was looking at my sr4130 on the driver side today.. seems like I got them reversed. I couldn't count any difference in coils or notice any height difference.. Maybe one is a stronger spring? I think when I take out the daystar lift this month, I'll swap them left/right
gaber6 is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 09:27 AM #22
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
LOL, I'm probably the only one who likes to hear that the Toyota OEM shocks are floaty, yet comfortable (for the 4th gen). I have the XREAS and lately (I constantly change my mind) couldn't justify replacing it with another XREAS. I had billies on a former ZJ Jeep I had and couldn't stand it. I could run over a quarter and tell you the year it was minted, it was THAT stiff (to me). I heard KYBs are less stiff, but still on the hard side. When my XREAS shocks blow out (they were replaced several years ago with new XREAS shocks), I guess I'll settle for the OEM shocks.
CookieRoe is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 10:27 AM #23
SR4130 & SR4131
yes those are the right number, but any reputable parts store should give you the correct part # based on the year 4runner you provide, & the 4wd are different than 2wd.
also be sure to install on the correct side, they will be marked L & R or the part# will designate L&R.
also the KYB are not really considered stiff or firm, just slightly (~10%) stiffer than stock SR5... XREAS provides a different feel & is firmer on corners etc, thats why poly sway bar bushings are a good upgrade to keep the 4runner from feeling top heavy on corners.
Old 10-01-2020, 05:35 PM #24
Kyb quick strut are far from firm for sure. A fair, smooth riding replacement I'd say
Old 10-01-2020, 05:53 PM #25
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Good to know, thanks!
EDIT: I'm at about 175K on the clock, maybe my bushings "aren't doing so well".............. Pretty sure they are the originals.
Old 10-02-2020, 07:39 AM #26
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
I've beat the F out of my rig. These Bilsteins have lasted 3 years with 35's and HARD wheeling. They bent but didn't break!! Just got new ones this week- I don't think I'll do any other brand and I'd like to upgrade to the ones with remote reservoirs someday.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 11:43 AM #27
i replaced my xreas at 145k, they werent leaking but had a very poor ride although corner handling was still ok. after the kyb's, the overall ride improved a lot but i noticed the cornering firmness was gone, still totally acceptable & far better than many GM suvs ive ridden in but i will be adding the poly s/b bushings soon after reading some threads in here about them.
Old 10-03-2020, 05:51 PM #28
Urbanite Urbanite is offline
Urbanite is on a distinguished road
I also have the XREAS 2WD. On my fronts, it's very noticeable where clearance between fender edge and tire is like 3" but on rears it's like 6.5," and I'm wondering if my shocks are shot. I've attached pictures showing front shocks. The right side has more "sweating" than left. The ride feels balanced, but I'm relatively new to this truck and not sure what the norm is.
When I went on Amazon to search for KYBs, they showed shocks without the coils for my truck. Do I not need coils? Some websites show shocks and coil as a single unit. I also read somewhere that KYBs were stiffer than Bilsteins, which is not what this thread says.
I don't do any off road driving and no such plans. I need a comfortable ride that's composed and not bumpy! So if someone would advise as to what would work for my truck, or if I even need new shocks, I'd be very appreciative.
KYB Excel-G or Bilstein?-shock1-jpg  KYB Excel-G or Bilstein?-shock2-jpg
Urbanite is offline   Reply With QuoteReply With Quote
Old 10-03-2020, 07:10 PM #29
PC1978 PC1978 is offline
PC1978 is on a distinguished road
Partial answer here.
I’m sure someone else can clarify with more details.
I also don’t know what other steps are involved with the XREAS system vs the normal suspension setup.
Yes, you need the springs/coils.
If you are wanting to keep a softer ride, I would buy the fronts without new springs (with the springs are called quick struts), and reuse your existing springs.
Many times the basic brand quick struts and premium coilovers come with stiffer springs than OEM.
Which will firm up the ride but can also improve handling/reduce body roll, it’s a trade off.
The quick struts do offer a slightly easier install, since they are completely assembled with new mounting hardware.
To reuse your existing springs you will need a set of spring compressors (around $40 at an auto parts store), and probably a new mounting hardware kit (unless your purchase comes with the mounting hardware) as you’ll likely want to replace the bushings.
Example of how to use the spring compressors here:
HOW TO COMPRESS STRUT SPRING - YouTube
Different brands offer different models of shocks (different characteristics), so that may be where some of the confusion is coming in on which brand offers firmer/softer ride.
I’m not sure what KYB and Bilstein off for the 4Runner.
But my son has been looking at some Bilstein’s for his 2008 BMW 328i.
There are several options/performance levels available from Bilstein for his car, firmer options offer better handling characteristics for “spirited” driving but also make the ride rougher.
PC1978 is offline   Reply With QuoteReply With Quote
Old 10-03-2020, 11:25 PM #30
I just checked fleabay for those XREAS shocks, and one dealer is asking $555 for both sides. It looks like shocks come with a few extra attachments, like a high pressure air hose. I'm wondering if I can get away with just buying only the shocks from Amazon and use existing hardware/ attachments? This would be much better for my budget. I'm wondering what others with the XREAS did. Here's the fleabay link for the overpriced OEM stuff.
Toyota 4runner 2003 - 2009 4wd Front Shocks Set W/ Reas Genuine OEM OE for sale online | eBay
https://www.ebay.com/p/656127736?iid...8aAnJcEALw_wcB
bilstein , excel-g , kyb , road , strut
Overextending Bilstein 5100 rears with my 3" lift, which Bilstein 5125 part? str8flexed 5th gen T4Rs 20 02-22-2019 12:45 AM
New Product Release: KYB Excel-G Struts: 2010-2014 Toyota 4Runner / FJ Cruiser TotalAutomotiveLV 5th gen T4Rs 0 02-17-2015 07:11 PM
FS: 3rd gen Bilstein 5100 w/ Eibach Coils & Bilstein 5125 Rears - Honolulu - $425 +S awpsome For Sale: Suspension/Wheels/Tires 4 08-21-2014 10:47 PM
Mix and Match KYB GR2 and Excel G phil123 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-11-2012 09:27 PM
Plotting Data with Excel greasefingers Off Topic 3 01-14-2006 04:22 PM
