Originally Posted by jay333
I'm wondering how my current lift might compare to that of others (in particular those that have installed the kyb or even bilstein shocks). I took a few moments to measure the front and back on my 2003 V8 Limited (currently with the stock XREAS). I have about 160k miles on the vehicle and wonder how much if any the front (or rear) might have sagged. anyways, for what it is worth my current measurements from centre of wheel to bottom of fender is 18-5/8" at front and 21-1/4" at back. So currently there is a difference of about 2-5/8" from back to front (at least on that particular measurement).
i always measure from the ground to bottom of fender edge, inline with middle of wheel, easier than holding the tape measure at the center of the wheel. but will still tell you the difference between front & rear.
with the KYB, mine measures 35 1/8-1/4" front & 36 1/4" rear. so its a difference of about 1-1 1/8", & looks close to level when looking from a distance. i posted my before measurements in another thread & you can clearly see the difference in the before/after pics i posted on this thread.
based on your measurements i would say your front springs are sagging quite a bit & the kyb will bring the front back to original height plus a little over an inch more. the rear will stay the same since/if you dont change the back springs. the rear of mine still sits plenty high & probably like stock based on other stock 4runners ive seen.
cant comment on bilstein heights since they require springs of whatever brand/rate you choose & most people use one of the 3 lift options for the front shocks the 5100's offer.
