Old 10-26-2020, 05:10 PM #16
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Guess i am not following...as in a bad yaw sensor?
Locking the center diff causes it to slip?
That make no sense to me... the locking of the center part.
If anything there is less chance of any slipping with center diff lock.
At least when i have used it... the diff lock.
This didnt do any shifting when it happened.
I did try to down shift to 3rd and 2nd with zero forward movment, then started to move slowly forward, another 2 miles down the road all was normal transmission action again.
Really weird behavior.
If you break a front cv on the v6, will it loose traction to the rear wheels? In 2wd.
Cant remember if that was just the v8 that did that? Because its awd.
And like i said it was a one time deal, so far, so really hard to test ideas to try if i cant recreate the initial issue.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 10:34 AM #17
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
Well, no... not like that. This was my theory:
For some reason (like the angle your truck was sitting at the moment,) I thought MAYBE the ECU was activating the traction control which reduces power to the wheels.
To test this idea, I suggested you lock the center differentials briefly if it happened again. Not because you needed more traction though -- When you activate the center differential locker, it also turns OFF the traction control systems.
Now that I'm reading the posts again... something you may want to check is the white plug going from the ECM to the transmission (driver's side of the transmission, just under the gas pedal area) for corrosion. The whole "acting like it's in neutral and then it's fine later" symptom sounds like something I went through a few years ago, and I had corroded pins.
Montego Murph is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 01:06 PM #18
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
When i had that little slip there were not any beeps, grumbles or any trac control noise or lights.
Copy that, will check that conection.
AuSeeker mentioned it too...was thinking he ment in the trans pan at the selinoids.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 10-27-2020, 01:12 PM #19
AuSeeker knows the drill -- he and I did a lot of learning about that cable a year or two ago.
That is the other end of the cable I speak of -- it comes in two parts.
The external cable connects the ECM to the Transmission (white plug) and the other is inside the transmission, going from the white plug to the valve body which houses the solenoids.
Solenoids are little electric plungers (sort of like the rebound springs on a pinball machine) that open and close valves in the transmission which direct fluid down different paths.
miles , normal , road , stop , turn
Oil change interval for 4Runner that sits? atalarico 3rd gen T4Rs 20 09-21-2016 11:55 AM
My 97 4runner build. From when I bought it to how it sits now Toymaker 3rd gen T4Rs 2 06-20-2015 11:57 PM
Level 8 Punch Now Available Discount Tire Discount Tire 0 10-21-2013 07:44 PM
Hmmmm, swap.... cometobanks Classic T4Rs 7 09-25-2012 11:55 AM
