Old 10-09-2020, 05:52 PM #16
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Originally Posted by djpope09 View Post
That test kit looks awesome. How lean is your bank 2? I've noticed that my LTFT on that bank is around 10% while the other bank is closer to 0%. I haven't been able to figure out why. I don't have a whistle like yours, but I also haven't tried to track down any vacuum leaks. I'm interested to hear what you find.
My LTFT bank 2 is 7.81% and bank 1 is 0%. So it has to be at the intake or cylinder level. I was concerned that it was a head gasket leak affecting the fuel trims. So fuel injectors are cheap $30 ea rockauto reman. The gaskets are cheap $5 each. So the plan now is to pull the intake plenum and reseal the runners and replace injectors. The spark plugs are new and I switched the igniters from left to right with no change. Its not ignition related. I do have a p0446 large vac leak and from what I have read seems to be a charcoal canister seam leak. A lot of silicone or JB weld will be used and hopefully resolve that issue. The emissions leak would alter both banks LTFT so these must be different problems.
The test kit is a Lisle tool I bought at Advanced Auto parts. $42. It attaches to the vac port with a hose.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 11:45 AM #17
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
Long & Short Term Fuel Trim
Great subject with the head gasket and the approach to trouble shooting.
You mention the differences between bank 1 and 2. I'm very green interpreting this information. What exactly is this showing us?
Head gasket question 2007 4runner V6-img_4309[1]-png
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 11:51 AM #18
Real Name: Kevin
Real Name: Kevin
What Fuel Trim Values Should Be
Ideally, the STFT and LTFT should be within a few percentage points of zero when the engine is idling or being held at a steady RPM. Remember, STFT can bounce around quite a bit as when you suddenly snap open the throttle or decelerate. But LTFT can tell you if the average fuel/mixture is running rich or lean.
Good LTFT values should be as close to zero as possible, though they can range from 5 to 8 percent depending on the condition of the engine. If the LTFT is getting up around 10 percent or higher, it usually indicates a problem that needs to be diagnosed.
Old 10-10-2020, 02:00 PM #19
Drcoffee's Avatar
Drcoffee's Avatar
In order to get accurate fuel trims the coolant temp should be 175*F or higher first. Then check. It looks like you have a general small vacuum leak because both banks are running lean and adding fuel to compensate. But well within limits the computer can control
Watch this video and it will explain all
Secret of Engine Problem Diagnosis- Fuel Trims Pt.1 - YouTube
Old 10-10-2020, 04:08 PM #20
Real Name: Kevin
Real Name: Kevin
Awesome,
Thanks
coolant , gasket , head , leak , system
2007 Head Gasket Replacement - $4k basselope 4th Gen T4Rs 25 10-25-2018 12:24 AM
V6 Head gasket question Mellemel 3rd gen T4Rs 2 04-23-2015 11:37 AM
Is the head gasket an issue in the 2007 v6? jnat306bg 4th Gen T4Rs 0 03-27-2013 10:13 PM
1995 4Runner-Bad Head Gasket Question mikedks Classic T4Rs 8 01-17-2012 07:27 PM
'95 Head Gasket question metallicarox Classic T4Rs 6 09-13-2008 01:14 PM
