Old 10-04-2020, 01:28 PM #1
gigajoe's Avatar
gigajoe gigajoe is offline
gigajoe is on a distinguished road
gigajoe's Avatar
Any experience with this for bleeding brakes?
Amazon.com: Allstar Performance ALL11017 Bleeder Bottle with Magnet and Check Valve: Automotive
If the link does not work, its a bottle with a check valve built into the cap.
gigajoe is offline   Reply With QuoteReply With Quote
Old 10-04-2020, 01:35 PM #2
Cezar Cezar is offline
Cezar is on a distinguished road
Hahaha jesus no don't buy that. Get either the motive bleeder, or optionally you can just use a block of wood between the brake pedal and the front seat to wedge the pedal down.
Cezar is offline   Reply With QuoteReply With Quote
Old 10-04-2020, 01:45 PM #3
gigajoe's Avatar
gigajoe's Avatar
What is it that you see wrong with this? If the check valve works as claims, it should keep air from entering back into the lines no? There are a lot of claims in the comments and reviews of techs using this.
Old 10-04-2020, 02:01 PM #4
It probably can and does work...mostly. You just don't need to spend money on cheap hacks that introduce margin for error when there are solutions at the top and bottom of the price range already. Bottom being $0 using a block of wood. Don't waste tool budget on shit unitaskers. This is Alton Brown speaking.
Old 10-04-2020, 02:57 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I would rather install speed bleeders than try and use that product, same basic principle but you don't have to worry about the tubing sealing and staying on properly to the OEM bleeder valve to keep air out.
2004 Limited V8
Old 10-04-2020, 03:50 PM #6
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Clear tubing and a plastic bottle will accomplish the same thing.
Fill it up like 1/4ish of the way and you're golden.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 10-04-2020, 03:57 PM #7
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
It probably work, but $25 I wouldnt buy it. For me, i bought the universal Motive mount for toyota/lexus, rigged the hose with a quick connect to my air compressor, set thr line pressure to 14 PSI and bleed the brakes that way. And because the flow is continuous, I end up using less brake fluid. Tip: with a hammer or mallet, tap the caliper to free up air bubbles.
I have also been successful bleeding the calipers by using a basic catch cup. Orient the catch cup hose so the hose on the bleeder screw points up. As you press the brake pedal, the air bubbles rise well above the bleed screw and any fluid drawn back as you release the brake is free of air. Worked for me many times. But Im lazy, and the motive system without the pump jug has made the job so easy. Make sure not to exceed 14 PSI tho.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 10-04-2020, 04:46 PM #8
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
Don't need anything fancy that's going sit around collecting dust 99.999999% of the time before disappearing just before you need to use it again.
I replaced all 4 brake calipers and all I used was a small board wedged between the brake pedal and the seat.
Hunter61 is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 08:34 AM #9
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
I use the one man bleeder bottle that you can get at Autozone for like 10 bucks. Pretty much the same thing - just a bottle with some tubing and a check valve. Worked just fine for me when replacing my calipers recently!
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 10:15 AM #10
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Another vote for Speed Bleeders. There's a link to brake work in my build thread with links to the threads I followed.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 03:41 PM #11
gigajoe's Avatar
gigajoe's Avatar
Reporting back. I bought one, just used it. I had just recently replaced all calipers and pads prior. The thing works like a dream. I used it with some additional feedback from this thread. I know some were mentioning the motiv, but for 60 bucks vs 20, I thought Id chance this. Just to recap my procedure. Ignition on, started with the RR, RL, FR, then FL. I had a large piece of concrete I used to hold the pedal down for the rears. I could hear the pump run for both rears as it continuously pumped fluid out. Probably didnt need the check valve for those. The fronts are what I was more concerned with. I pumped the fronts a few times each. While doing this I noticed bubbles in the line at first, but the check valve worked and locked them in place. I pumped until I saw no air bubbles and used the piece of concrete to lock the pedal down then tightened. In retrospect a one man couldve probably been done utilizing a bottle and hose locking the pedal down with the concrete. I had no hose or bottle so i would've had to buy something regardless. So for 20 bucks I got some piece of mind in the check valve, that did work, and given the freezing caliper issue on the 4th gens, I plan on doing this at least once a year to help clear the lines and add fresh fluid. Took 10 minutes if that. Would recommend if you have no assistance and need any supplies to do the job at all. Thanks guys and gals, pedal is hard as it should be.
bottle , built , check , valve , work
brakes/bleeding doubleA 4th Gen T4Rs 6 08-14-2017 10:33 AM
Need some help - Bleeding brakes wkeryder4 4th Gen T4Rs 8 08-23-2014 12:05 PM
Bleeding my brakes oa8888 Maintenance/Detailing 5 12-21-2009 08:15 PM
Bleeding brakes sciff5 4th Gen T4Rs 1 03-14-2009 06:46 PM
Bleeding Brakes kimboy Maintenance/Detailing 3 07-06-2008 05:47 PM
