10-10-2020, 11:42 AM
#16
Originally Posted by xtremewlr
No, doing the fluid exchange via the cooler port is so ridiculously slow, it's not worth the time and effort. I tried it on my 2003 and it took like 6 hours to do. Just stupid. The simple drain and fill for the 2003 is really the best way to do it. If it really is only 25-30%, then I'd just do it 3 or 4 times with the drain and fill method. I'm not going to waste my time with the cooler line again.
I have done my seinna and my 4runner by flushing with pump.. Its fast and easy.. I followed this guys method, most of it.. Its fast and easy.. 5-10 mins done for actual flush. About 20mins to setup...
I mentioned here before and guys are saying wrong and this, that.. Whatever it works for me and 50k miles later, no problems... The other ways is just slow and doesn't feel complete. But whatever, its your car.
[Electric PUMP] flush automatic transmission fluid Toyota 4Runner ? Fix it Angel - YouTube
Sent from my SM-N960U using Tapatalk
10-10-2020, 07:01 PM
#17
Btw..if the atf at 160k looks pink/reddish...id saybthe 4r had a atf fluid change of some sort...
10-10-2020, 07:20 PM
#18
6 hours?? why? i think you are misunderstanding how to do a exchange via the cooler line. many people have done it this way including myself & it took all of about an hour. you simply use the outlet port on the bottom of the radiator with a short piece of rubber hose into a measured container, engine pumps out ~2qts & you refill 2 qts.... via the fill hole in the side of the trans. not through a cooling line, that is why it was ridiculously slow, no reason to do that, there is a fill hole on the trans for a reason. ive used a hand pump but a faster way is with a funnel held in the passenger side of the engine bay with a tube ran straight down to the fill hole. takes literally 2-3 minutes to refill 2qts. quick & easy job.
for his 4runner with a dipstick its even easier... you pump out the 2qts the same way described, then simply put a funnel in the trans tube & refill... bet a full exchange would take about 30 minutes including clean up..
10-10-2020, 10:21 PM
#19
Real Name: Calvin
Real Name: Calvin
Originally Posted by jay333
Thanks. Do you normally replace the drain plug washer/gasket each time as well?
The drain plug crush washer has to be replaced. Too cheap to not do, and you’ll see why you should when you remove it. If the older trans pan is similar to the newer one, be very careful putting the plug back in. I accidentally torqued mine to 20 ft/lbs instead of 15 and stripped the threads on the pan.
2006 Sport Edition 4x4 V8
Bilstein 6112 w/ King 700# springs (5th clip), Toytec 2" springs in the rear w/ ICON 2.0,
CBI single hoop front bumper, Smittybilt 9500 XRC, RCI steel full skid package, 285/70r17 BFG KO2s on TRD Offroad wheels
10-10-2020, 11:23 PM
#20
Real Name: Carlos V.
Originally Posted by firebirdguy
...simply use the outlet port on the bottom of the radiator with a short piece of rubber hose into a measured container, engine pumps out ~2qts & you refill 2 qts.... via the fill hole in the side of the trans...
For his 4runner with a dipstick its even easier... you pump out the 2qts the same way described, then simply put a funnel in the trans tube & refill... bet a full exchange would take about 30 minutes including clean up..
As Firebirdguy says, is how a did it (learned from him here T4R.org) in my 2003 V6 (with dipstick). Valvoline Max life. 12qts. 45 minutes. Very easy.
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
10-24-2020, 08:07 PM
#21
Too much transmission fluid?
I have another (hopefully last) related question to the transmission fluid replacement. Before I begin I checked the transmission fluid via the dipstick. Fortunately, it does look very pink and light in color. Regardless I am going to change it. But I noticed that the current fluid level as indicated on the dipstick seems very high. It is measuring a good inch on the dipstick above the highest 'hot' notch (and the engine is cold). The vehicle is sitting completely level. For those who may be familiar with the dipstick it is measuring up where the dipstick has its second twist (again about an inch above the max hot notch). How problematic is this? Any comments? Is too much transmission fluid a bad thing? Thanks.
10-24-2020, 10:24 PM
#22
Real Name: Todd
Real Name: Todd
You check fluid level with the transmission hot (drive around for 5 minutes or so). Have the motor running, shift thru all the gears on the shifter, Park down to L and back, you don't need to drive for that. Put it in park, leave the motor running and then check fluid level.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
10-25-2020, 10:25 AM
#23
if you are checking it the right way with engine/trans fully warmed up & engine running in park, then yes, an inch over the full hot mark is way too much fluid, & if its cold then its even worse. do a drain & fill to the right level or full flush & check the level when done. id do longer than 5 minute drive, when i check my trans temps with a scan gauge, 5 minutes barely gets it to 100*f, fully hot is closer to 140-150. but either way, yours is too full based on the reading you described.
tgis is the right way to check trans fluid, but id do longer than 5 minute drive from totally cold, when i check my trans temps with a scan gauge, 5 minutes barely gets it to 95-100*f, fully hot is closer to 140-150 that takes ~15 minutes of city driving, highway may be a faster warm up.
