Old 10-12-2020, 11:10 AM #1
PhantomF4E PhantomF4E is offline
PhantomF4E is on a distinguished road
Peculiar Behavior (Gear Shift)
I've got a 2006 SR5 (193K miles), and I had the dreaded "won't shift out of park" episode the other day, and after searching the forums, I looked at all of the fuses in the area to the left of the steering wheel and none were blown (I was thinking it might be a brake lights issue, but I had the wife press the pedal and they both worked fine).
Long story short, it happened a few times, and I was able to get it shifted by using the shift interlock button to release it manually. After I checked all the fuses and replaced them (as none were blown), I haven't had it happen again. I'm not worried if it does as I carry a small Gerber-type tool in my vehicle just in case, but I'm just curious if anyone has other ideas on what may have caused it. Seems like it could be a variety of different things, but I guess I thought for sure I'd find a blown fuse of some sort.
As an aside, I will say that I had some work done on the rear bumper lately (picked it up on Friday from that work and this happened Saturday morning), and seeing as I have a tow package installed, is it unreasonable to think that perhaps when they were doing the work to the rear bumper, they messed with the wiring harness for trailer light hookup? I've hauled trailers and things before and never had any issue that I was aware of...
PhantomF4E is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 11:19 AM #2
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
If there's any chance that some drink or coffee has gotten spilled in there that could be the culprit. I've seen it many times. Especially if it was a drink with sugar it it. It can gum up the mechanism and cause it to not work. It's not all that hard to happen either, considering the location of the cupholders in relation to the shifter. If so, you just have to clean it out and maybe spray a light lubricant in there and it will work fine again.
importman is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 02:24 PM #3
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Brake Switch?
A bad brake switch will cause the same issue intermittently but may have accompanying dash lights as well. Cheap, easy swap if it's the culprit, should be plenty of threads on it around here.
eleven14 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 03:05 PM #4
montijo505's Avatar
montijo505's Avatar
Mine did the same thing, intermittently at first while the brake lights were still working. Replaced the switch, all is good. It's under $25, easy fix. Part number in the pic below. I got it from McGeorge, which I have always had a good experience with.
Sent from my SM-G986U using Tapatalk
Old 10-27-2020, 12:42 PM #5
So after checking the fuses and stuff, the problem stopped for a while and now it has come back so I'm going to order the stop lamp switch and see if I can just install it on my own. Hopefully this is the trick! Thanks again for all of the great advice. This forum has helped me learn a great deal about my vehicle and I think I enjoy it even more now as a result.
In related news, I'm going to try and find a replacement cap for the shift lock override button. It doesn't lock in place anymore.
Old 08-23-2021, 11:52 AM #6
3.5Runner 3.5Runner is offline
3.5Runner is on a distinguished road
Did the stop lamp switch end up doing the trick? Sounds like I'm in the exact same scenario you were in (brake lights are working perfectly, no blown fuses and there doesn't seem to be any mechanical issues within the shifter assembly after taking the whole thing apart) and now I'm considering buying a new switch in the off-chance that's what's causing my transmission to be stuck in park. If that wasn't your issue after all, mind sharing what it ended up being?
Sent from my SM-N975W using Tapatalk
3.5Runner is offline   Reply With QuoteReply With Quote
Old 08-23-2021, 06:52 PM #7
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Unfortunately @PhantomF4E hasn't been on the forum since November of last year, so you most likely will not get a reply from him.
I have "mentioned" him in this reply so it's possible he will get an email saying so and may visit the forum, but if he doesn't reply within a couple of days you might want to just get the switch and try it, it's easy to replace and not extremely expensive, especially if it solves your issue.
2004 Limited V8
Old 10-23-2022, 05:29 PM #8
This is over year late in reply, but thank you to everyone who replied. I was about to make a new post on an unrelated topic, but figured I'd say my thanks on this one first!
blown , bumper , issue , shift , work
FS 5th Gear shift knob kuyaariel For Sale: T4R Items 1 11-17-2018 08:48 PM
Gear shifter really hard to move/shift into gear (auto trans) infamousRNR 3rd gen T4Rs 7 07-03-2018 03:42 PM
Would not shift to the next gear mnunez021 5th gen T4Rs 3 03-14-2012 05:22 PM
Gear shift dullpain 4th Gen T4Rs 1 02-26-2010 02:20 AM
VSC/ABS lights on, can't shift into gear? Any help? Ryan32 4th Gen T4Rs 8 12-16-2007 04:00 PM
