Old 10-12-2020, 12:09 PM #1
ram120 ram120 is offline
ram120 is on a distinguished road
Urgent: help with tires and trd pro rims !
I'm new to learning about the tires and wheels friends, but I knew I wanted the TRD Pro wheels (17x7) PTR20-35110-GR.
Friend recommended 255/75/r17 wheels so got myself the Firestone destination AT2 tires and dropped all off at the shop first thing the mechanic says is these rims look small for those wheels??
Please tell me it's fine! Or do I need to get a skinnier wheel? Thanks! Urgent: help with tires and trd pro rims !
ram120 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 01:03 PM #2
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
Absolutely fine. TRD Pros come factory with 265s, 10mm is nothing.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 01:16 PM #3
FrothyLlama's Avatar
FrothyLlama FrothyLlama is offline
FrothyLlama is on a distinguished road
Yeah, they should be fine. Is the mechanic going to mount them? Why is it urgent?
Sent from my Pixel 3a using Tapatalk
2006 SR5 V8
2.5/2.0" Lift (Dobinson Fronts C59-314, Dobinson C59-327 Rears)
Fuel 17x9 -12 offset D531 Hostage Wheels
265/70r17 Cooper Discoverer A/T
FrothyLlama is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 01:41 PM #4
mjg514 mjg514 is offline
Real Name: Matt
mjg514 will become famous soon enough
Real Name: Matt
those wheels are def not too small for that tire size. i have those wheels and i'm running (as well as many others on this forum) 285/70r17, no issues at all.
mjg514 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 01:49 PM #5
montijo505's Avatar
montijo505's Avatar
255/75 are ideally run on 7-8.5" wheels. Should be a perfect fit.
Sent from my SM-G986U using Tapatalk
Old 10-12-2020, 03:01 PM #6
dunno he contacted me like "these rims look small" just like passively and I'm like I did my research...
Thanks guys
Old 10-12-2020, 03:09 PM #7
montijo505's Avatar
montijo505's Avatar
Thanks guys
They're the same as OEM. I could see if you were trying to mount some 37s maybe, but especially with the skinnies no issue whatsoever.
You can run into the reverse issues with skinnies, wheels are too wide, like trying to mount skinnies on a 9" wide wheel.
Old 10-13-2020, 10:36 AM #8
4th gen 4runners came stock with 265/65/17 tires that are 30.6" tall. a common step up in size is the 265/70 that is 31.6" tall, 1" taller than stock. 5th gens use the 265/70. the 255/75 is 32.1" tall, 1.5" taller than stock 4th gen. the 255/75 is not an oem size for 4th or 5th gen 4runners but is close. however, if you have stock suspension & it is sagging at all, those 255/75 tires "might" rub in some situations unless you have a small lift.
& just an FYI on terms, tires are not called rims or wheels, they are called tires. the wheel or rim is what the tire installs on. heres a helpful link to compare tire sizes...
GM TH-350/TH-400 Flywheel/Flexplate Dust Cover, Black
Old 10-13-2020, 12:09 PM #9
codeman528 codeman528 is offline
codeman528 is on a distinguished road
Im running 255/75/17 tires on TRD Pro wheel and think they're a perfect fit! Never had any issues or second thoughts.
2005 V8 Sport Edition 4WD | Bilstein 5100 | OME 885 and 895 | TRD Pro Wheels | 265/70/17 Falken Wildpeak AT3s | USA Spec Bluetooth Audio | Rago Fabrication Molle Panel | Victory 4x4 Front and Rear Bumpers | BajaDesigns Squadron Sport Ditch Lights | Morimoto HID Retrofit
codeman528 is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 03:01 PM #10
Nashvillerunner Nashvillerunner is offline
Real Name: Jason
Nashvillerunner is on a distinguished road
Real Name: Jason
You shouldn't have any issue with that wheel and tire combo. I know plenty of people that run that combination and have zero issues. It sounds like to me you need to find a new mechanic.
FJC SUSPENSION/DEBADGED/DDM TUNING 5000K HID KID/DDM 9006 YELLOW LED FOG LIGHT BULBS/YAKIMA MEGAWARRIOR BASKET/265-70-17 FALKEN WILDPEAK MT-01.
Nashvillerunner is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 02:11 PM #11
Thanks so much guys, tires fit great on those rims. I'm running a stock suspension and having an issue with rub in a strong left or strong right like when backing into a spot..
Old 10-14-2020, 02:22 PM #12
I’m slightly higher than stock and had the exact same issue. In my case it was only rubbing on the front of the fender liner; a little trimming and a zip tie or two took care of the problem!
pro , rims , tires , trd , wheels
FS: All gens Brand New Tires/ Used Rims - Black $850(tires)/$550(rims) Black - Atl,GA Bao!OhNoes For Sale: Suspension/Wheels/Tires 0 01-18-2017 03:16 PM
WTT: FJ Cruiser rims and tires for Limited Rims and tires A_HuL For Sale: Suspension/Wheels/Tires 2 09-12-2012 09:50 PM
Norcal Feeler: Trade my 20" LE tires/Rims for your 17" TE Rims/Tires bamma For Sale: Suspension/Wheels/Tires 2 07-08-2012 07:10 PM
WTT: my '10 sr5 rims/tires plus cash for your '10 ltd rims/tires BlizzardSR5 Classifieds - buy & sell (no commercial ads please) 0 09-18-2010 02:41 PM
WTT my tires and rims for your stock rims and tires VA97T4R 3rd gen T4Rs 0 12-17-2007 05:30 PM
