Old 10-14-2020, 02:27 PM #1
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
Adventure Runner Pre-Built Build Thread
Some of you might recall the member @blackoutt and his 2007 Galactic Limited, well for the past year and some change I've been the very proud owner of this baby right here and figured by now I've done enough to make a thread of my own/revive his build for those interested in information. I'm adv_runner on IG for some pretty alright content. I've been dealing with a slight sickness for almost a year, but now that it's getting better it's time to use this thing more!
As of last weekend on an impromptu, no gear camping trip here's how she sits.
The day I brought her home!
Things done before my ownership:
Suspension
- Fox 2.5 extended front coilovers w/ remotes and DSC
- Fox 2.0 10" travel rear shocks
- Dobinson 677V rear springs w/ 1.5" Daystar driver side spacer
- SPC upper control arms
- Icon SS shock skids/roost guards
- Wheelers Super Bumps front and rear
- StopTech extended stainless brake lines
- Energy sway bar bushings and lateral lock collars
- Diff breather extended to gas filler
- 1" body lift
- DIY EPDM fender liners
- OEM front LCA w/ Moog BJ and Energy bushings
- OEM rear control arms w/ Energy bushings
- Toytec adjustable panhard bar
Exterior/Armor
- (5x) KMC 301 Turbines 17x9 -12
- (5x) Cooper STT Pros 295/70
- Prinsu full roof rack w/shorter spacers
- White Knuckle Offroad DOM rock sliders
- Metaltech rear lower link skids
- Rocksteady aluminum front skid
- Rocksteady aluminum trans skid
- Rocksteady aluminum front bumper filler plate
Interior/Camp
- Adventure Index drawer system w/ sleeping platform
- Partner Steel 22" stove
- Dometic CFX 40W w/ bag
- DFG tilting fridge slide
- ARB fridge plug socket
- Blue Sea dual USB charger in center console
- Blue Sea dual USB charger in rear
- USB fans
- RAM phone mount
- Anytime backup camera switch
- Traction aids off button
- Rear hatch LED lights wired to cargo switch
Recovery/Tools
- ARB CKMTA12 twin air compressor on custom mount
Power
- (2x) Odyssey Batteries 34R-PC1500T
- Off Grid Engineering aux battery tray
- Off Grid Engineering starter battery tie down
- Starting battery spacer
- GM OEM part# 12135037 alt-s diode
- Dual battery voltage monitor in center console
- Blue Sea SI ACR
- Blue Sea fuse panel
- Renogy 100W Eclipse solar panel
Lighting
- Eagle Eyes Sport headlight housings with G5-R retrofit
- LED interior lights
- LED step bar lights
- Anytime fog light mod
- TINman 3d printed sunglass holder switch plate
Engine
- Doug Thorley headers w/ 2.5" catless downpipes
- Doug Thorley Y-pipe
- Flowmaster super 50 SUV muffler
- Resonator delete, side exit
- HCF delete
- URD O2 sensor simulator
- AFE Pro Dry air filter
- Smooth intake tube
- Slyfox AIP bypass kit
- Fumoto oil drain valve
Since I've owned it:
Exterior/Armor
- (5x) SCS F5s 17x9 -38
- (5x) Goodyear DuraTracs 315/70
- RLC Fabrication one-off rear bumper with swingout
- C4 Fabrication Lo-Pro front bumper
Interior/Camp
- ARB 2500 awning w/ mounts
- 2 gallon water Rotopax mounted inside
- Trasharoo tire bag
Recovery/Tools
- Warn VR8-S winch
- Factor 55 fairlead
- Factor 55 Flatlink-E
- (2x) Maxtrax recovery boards
- Treaty Oak 3/4" x 30' recovery rope
- Treaty Oak 3/8" soft shackle
- Treaty Oak tree saver
- (2x) Van Beest 3/4" shackles
- (2x) 4 gallon Rotopax fuel containers
- 52" Plano case
Lighting
- Baja Designs Squadron-R fog lights on factory switch
- Baja Designs S2 flush mount reverse light
Future plans:
- NTK Fab body mount relocation
- Eimkeith panhard correction kit
- ARB rear air locker
- Brembo blank rotors w/ Hawk LTS pads
- Indeflate 2 hose unit
- Some snatch block
- Cobra CB/Diamond mount/Firestik antenna
- Safari snorkel w/ Syklone pre-cleaner
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 02:28 PM #2
Real Name: Aaron
Real Name: Aaron
For those interested in the drawers/bed/electrical that he put together here's some old picture of the process. I have all the details from old threads too for anyone if they need.
My first time out with it putting all these goodies to use.
The day of the new rear bumper. This was built by a local fab shop that intended to produce it, but since nixed that idea.
The new front bumper, winch, F55 stuff and S2 were all pretty straight forward. The fairlead and bumper weren't 100% plug and play which was a little disappointing. But all I had to was grind the bumper slightly on each side so make room. The wiring for the aux reverse light was already there from the old ones.
Right after the new wheels and tires a couple of weeks ago. Completely rub free on the old 295s, but now I have some cutting on the front bumper to do and I want to relocated the body mount altogether.
Old 10-14-2020, 06:57 PM #3
montijo505's Avatar
montijo505's Avatar
Wish I had the V8, that stance on the F5's and 315's makes my pants fit weird.
Sent from my SM-G986U using Tapatalk
Old 10-15-2020, 09:59 AM #4
Real Name: Aaron
Real Name: Aaron
The V8 is why I don't have a 5th gen anymore
Yeah same here, I knew I was gonna like the new wheel/tire combo but I had no idea I'd be so in love lol.
Old 10-16-2020, 12:18 AM #5
Jones25261 Jones25261 is offline
Jones25261 is on a distinguished road
That is one sexy beast!
Jones25261 is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 01:49 PM #6
TLar25's Avatar
TLar25 TLar25 is offline
Real Name: Taylor
TLar25 will become famous soon enough TLar25 will become famous soon enough
TLar25's Avatar
Real Name: Taylor
Good looking setup! That rear bumper looks killer! Love the angles
Sent from my ONEPLUS A6013 using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
TLar25 is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 03:36 PM #7
Real Name: Aaron
Real Name: Aaron
Thank you both!
I've ordered the body mount relocation kit, and panhard correction kit. So'll have some in depth photos of that install. Super ready to have full wheel lock again and get rid of this adjustable sway bar and it's clunking heim.
Old 10-16-2020, 11:52 PM #8
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Looks great man, looking extra thicc with those 315s! I do like the rear bumper a lot, neat to have something unique!
y=mx+b is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 01:13 AM #9
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
Can't you put 315's on your V6?
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 03:19 AM #10
montijo505's Avatar
montijo505's Avatar
Sure I could, just no budget to re gear for a while, so I'd suffer drastically until I could swing it. I'm just not sure how practical it is. In my area 33's have never let me down, I might try either a 295/70 next time or maybe pizza cutters, not sure yet.
Old 10-17-2020, 04:02 AM #11
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
Always loved this rig. Take good care of her, she will take great care of you!
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 02:42 PM #12
Real Name: Aaron
Real Name: Aaron
Thank you!! They are beefy that's for sure. Also I agree haha.
Send it.
Thank you very much. I definitely will do!
Old 10-19-2020, 05:03 PM #13
SherpaEquipmentCo's Avatar
SherpaEquipmentCo SherpaEquipmentCo is offline
official vendor
SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold
official vendor
Great looking rig!
Industry Leading Modular Storage Systems that allow you to Adventure with Confidence.
Our WebsiteOur InstagramOur Facebook
SherpaEquipmentCo is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 08:41 PM #14
montijo505's Avatar
montijo505's Avatar
Send it.
I think we're gonna get along just fine lol
Old 10-20-2020, 01:12 PM #15
Real Name: Aaron
Real Name: Aaron
Originally Posted by SherpaEquipmentCo View Post
Great looking rig!
Thank you!
Perfect lmao. I do wanna go to NM real bad
arb , battery , blue , front , rear
4rNCMTMs '19 Runner build & adventure thread 4rNCMTNs 5th gen T4Rs 11 06-12-2021 07:15 PM
Scout Runner's adventure thread Presa Canario 5th gen T4Rs 22 03-28-2019 10:14 AM
Rey the Runner Build/Adventure Thread specificimpulse 5th gen T4Rs 20 12-19-2016 06:56 PM
Hargravey's Adventure/Build Thread hargravey 5th gen T4Rs 20 08-12-2015 11:14 AM
fatbacks Build and Adventure Thread fatbacks 5th gen T4Rs 21 04-29-2015 07:04 PM
