Old 10-16-2020, 04:15 PM #1
gaswede gaswede is offline
gaswede is on a distinguished road
Broken shock and bent posts
I installed new rear 5100’s a few months ago. Noticed my rear mount pins were bent upwards on both sides. It took a ratchet strap and a lot of cussing to get the upper pin seated in the shock tower. Naturally, this put a lot of undue stress on the bushings. After some very mild off-roading the shaft snapped clean at the eye.
How the heck do I repair or replace these lower pins on the mounting bracket? The pins don’t actually look bent but maybe the bracket is. If that’s the case, then what???
Broken shock and bent posts-4a34ad82-44da-4832-925b-f99eb8c35043-jpg  Broken shock and bent posts-d5ad50b0-8f95-48df-a924-cc80193e8ae5-jpg
gaswede is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 05:21 PM #2
pauldub pauldub is offline
pauldub will become famous soon enough
You could pound them straight and hope for the best. I would sleeve a piece of pipe over them so that you aren't deforming the stud (post).
pauldub is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 04:33 AM #3
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
I had the same issue. I cut mine off, ground the post flat, and welded on some Teraflex shock mounts. Haven't had any issues since!!!
Teraflex Jeep Wrangler Shock Bar Pin Eliminator-Front Lower 1203700 (97-06 Jeep Wrangler TJ)
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 02:56 PM #4
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Just cut them off and install new shock mounts. The top can also be replaced with new mounts to make the shocks loop-loop, the pin-loop shocks seem to always break anyways.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 08:15 AM #5
Thanks guys. All great suggestions. I think the tab route may be the way to go.
bent , lot , pins , rear , shock
Raise your hand if you've broken or bent a rear drive shaft! Jetboy 5th gen T4Rs 3 05-21-2018 05:45 PM
broken shock? Toyotacolin 3rd gen T4Rs 15 02-20-2013 04:24 PM
Broken Driveshaft, snapped shocks, bent links, etc.. 4-Ripcord 3rd gen T4Rs 62 08-11-2012 04:42 PM
Glove box shock broken Hayn4R 4th Gen T4Rs 9 04-26-2011 01:55 PM
Broken Shock Brutus 3rd gen T4Rs 1 08-08-2009 02:27 PM
