Old 06-24-2021, 02:26 PM #1
Lewis&Clark Lewis&Clark is offline
Real Name: Dan
Lewis&Clark is on a distinguished road
Real Name: Dan
Exclamation Sounds from vents when fan or AC running
Sounds kinda like leaves in the vents but the nature of the sound changes so I suspect it’s mechanical. Perhaps a fan motor starting to die?
Starts and stops as I turn on or off the climate system. If I whack the dashboard, it’ll stop for a bit and then come back on.
What might it be and what parts should I consider replacing?
2008 4Runner V8 Limited ("Lewis"), all factory options.
Lewis&Clark is offline   Reply With QuoteReply With Quote
Old 06-24-2021, 03:41 PM #2
bmorey bmorey is offline
bmorey is on a distinguished road
I've had something similar in the past, but hard to tell for sure based on your description. First thing I would make sure would be to ensure all the vents are fully open on the dash. I've had a sneaky passenger close one before and it made a weird whistling the next time I used AC. Thought I had an issue, but it was simply partially closed.
EDIT: another thing I just thought of: Check your cabin filter. maybe some debris is on that! (Its behind the glovebox)
2004 4Runner Sport Edition 4WD Titanium Metallic -
Ironman 4x4 Lift and UCAs, 33s Falken Wildpeaks, Custom 2-Drawer System, Prinsu Rack, Frontrunner RTT, Ironman 4x4 Awning, Cali Raised Sliders, 1 Inch BL, Lost Trails Low Profile Front Bumper, Badlands Apex 12k Winch
bmorey is offline   Reply With QuoteReply With Quote
Old 06-24-2021, 04:35 PM #3
Humble Leader's Avatar
the 4runner blower fans are known to be a bit loud. there's always been a slight hum to mine but only noticeable if you have the radio off and windows closed (154K miles original blower fan btw). wife's RX has a hum too. many mistake this for a defective fan, even on brand new vehicles, but really they are just on the noisy side. some have replaced blower fans and claimed it has helped. if you are hearing a metal on metal grinding sound it could be the bearing going bad, at that point replace
1. take out cabin air filter. very easy on the 4runner, inspect for debris and probably replace at the same time
2. take a peek at the blower fan, look for debris. might have to remove the blower fan if there are leaves stuck at the bottom of it. not hard to do. 3 bolts. be careful not to snap the plastic trim clips on the trim below the glove box
3. if you drop the blower fan you can see if the bearing is loose, or worn out as well
1-3 above can be found on youtube, very easy DIY
Old 06-25-2021, 08:39 PM #4
Syr4RinNC's Avatar
Syr4RinNC's Avatar
It might be a part called the "servo". Unfortunately you have to rip the entire dashboard apart to repair this and most people just leave it. You can temp fix it often by thumping the dashboard or cycling through the temp from high to low
fan , it’ll , sounds , turn , vents
Rear floor vents always running Penguin_Who_Laughs 3rd gen T4Rs 6 02-12-2017 08:15 PM
Vents ceyese 5th gen T4Rs 2 05-01-2015 09:29 PM
'13 Runner - Sounds like a compressor running when turned off? 94hokie 5th gen T4Rs 8 01-07-2013 08:32 PM
Sounds like the fan or a/c is running even though its not scottr1752 Problems & Warranty Issues 0 05-15-2009 01:54 PM
