Old 10-20-2020, 09:11 PM #1
Clarkson! Clarkson! is offline
Real Name: Tristan
Clarkson! is on a distinguished road
Real Name: Tristan
Question 22005 4Runner Suspension Upgrade In Progress
Hi everyone, I am in the midst of my first noticeable upgrade to my recently acquired 2005 4Runner. This past weekend I installed Bilstein 2" lift springs in the rear, SLEE offroad steel braided brake lines, and Bilstein B5100 rear struts. This has given me exactly 2" of lift in the rear.
This next weekend I am replacing upper control arms, rebuilding lower control arms, replacing tie rods, and installing Bilstein B5100 adjustable struts. It looks like the previous owner put FJ Cruiser springs on the front based on the colros and the fact that they appear to have raised the front about 1" from stock. My question is, if I set the B5100 for 2.5" lift, and re-use the FJ springs does this mean I will get a 3.5" lift up front? If so, will I run into other issues and be better off selecting the 1.75" setting? I am upgrading to JBA high caster arms, but am unsure what else may be an issue and would like a heads up before I get too far into it. Thanks all for any advice you can provide, Here are some pics of this past weekends upgrades.
2005 SR5 4WD: V8 - Doug Thorley headers, Bilstein 5100s, Slee offroad steel brake lines, Tundra brake swap, JBA upper control arms, 33s on RockTrix wheels, etc.
Clarkson! is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 09:29 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I don't have bilsteins myself, this is just from some research I've done when looking into them. Hopefully someone with first hand experience will chime in: I'd avoid putting the front bilsteins to 2.5" and then using the 1" coil. Bilstein recommends that with any lift coil they be set to the lowest perch. I think you could get away with setting it a little higher like the 0.85 setting, but I'd avoid the very top perch
I have a writeup on the LCA rebuild, shameless plug: Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures). Let me know if you have any questions with the rebuild!
y=mx+b is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 10:42 PM #3
Real Name: Tristan
Real Name: Tristan
Thanks for the info. I've been trying to find some instructions from Bilstein but have not had any luck. Was thinking of going to 1.75“ up front as I think that will come close to leveling the 4runner. Do you happen to recall where you found the recommendation to stick to 1.75 on the strut? Thanks!
b5100 , bilstein , lift , rear , springs
2nd Gen 4runner 4'' Suspension Lift Progress and Pictures redrunn Classic T4Rs 24 09-14-2018 08:51 PM
2017 4runner trd pro icon suspension upgrade. Got2bpro 5th gen T4Rs 6 02-27-2017 09:55 AM
Suspension fix on a 2004 Limited V8 w/RAS & XREAS in progress Toynaround 4th Gen T4Rs 0 08-10-2013 12:29 PM
