Old 10-22-2020, 02:33 PM #1
jscott6's Avatar
jscott6 jscott6 is offline
Real Name: Scott
jscott6 is on a distinguished road
jscott6's Avatar
Real Name: Scott
Intermittent door lock/unlock issues
Door lock issues have all started in the past two months. Both rear doors will not lock or unlock with the key fob or door buttons, thinking shot door lock actuators on those. Although both stopped working at the exact same time.
The two front doors are different; both will always lock with the key fob and door button, but not always unlock. Front passenger door will unlock about 75% of the time, driver’s door about 10% with the key fob. The door button locks or unlocks them more often than the key fob, but not 100% 0f the time.
Is it safe to assume all the actuators are bad or going bad? Or is there something I can lubricate that might free them up or a try reprogramming?
The rear hatch continues to lock & unlock properly. I have changed the battery in the key fob.
jscott6 is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 02:55 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
When I lost a door lock actuator, it was only the one. In my case driver rear door. It would work iffy for a few months, then it just died altogether. Although it is possible for them to both go out at once, seems odd that 3-4 are acting up. I would pull the door cards off and check all the actuator cables. I'm not sure on wiring specifics for the actuator, but you could also get in there with a multimeter and see if you're getting an current, signal, something at the actuator plug. If the electo-magic is making its way to the doors and they're not unlocking, then it would be safe to assume the actuator,
I have a writeup on replacing my door lock actuator: 4th Gen Door Lock Actuator Replacement: Step by Step with Pictures. Let me know if you have any questions on the replacement
y=mx+b is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 03:17 PM #3
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
I find it odd that you are having multiple door issues at once. Electronics can have intermittent issues if the battery is starting to go bad.
Is your battery good? How old is it?
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 03:42 PM #4
jscott6's Avatar
Real Name: Scott
jscott6's Avatar
Real Name: Scott
Battery is 13 months old. No other electrical issues happening.
When the drivers door does not unlock, the switch does move a little bit, just not enough to unlock.
Old 10-26-2020, 03:20 AM #5
Kevin G. Kevin G. is offline
Kevin G. is on a distinguished road
Lightbulb
Probably the small dc motor inside each actuator assembly. A bit tedious, but if you have time and a workbench.......doable.
A few years ago, I bought 4 new motors off of eBay for 22 bucks total.
Hope this helps.
Kevin
Kevin G. is offline   Reply With QuoteReply With Quote
door , fob , key , lock , unlock
Door unlock/lock problem JC41 3rd gen T4Rs 38 06-27-2023 12:19 AM
Automatic door lock/unlock owen4runner Problems & Warranty Issues 27 04-20-2019 02:16 PM
Intermittent Door Lock Issues carichards8 Problems & Warranty Issues 4 04-08-2019 07:03 PM
Help please door won't lock\unlock Jeffdrive4runner 4th Gen T4Rs 5 11-23-2014 07:59 PM
Door lock/unlock programming steve73 5th gen T4Rs 2 01-29-2012 12:47 PM
