Old 10-24-2020, 11:02 AM #1
ghs215 ghs215 is offline
ghs215 is on a distinguished road
Unhappy HELP NEEDED - C1231 Malfunction in Steering Angle Sensor
I need some help figuring out where to start and what to do. FSM didn't seem to give me the answer or searching the forums.
I am getting the code C1231 Malfunction in Steering Angle Sensor with all the traction control lights on.
I tried the zero point calibration and it went off then shortly came back
Any info would help!
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
ghs215 is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 09:16 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Did this just come out of the blue or after you made some kind of modification?
Old 10-25-2020, 11:43 PM #3
Out of the blue, no mods.
Old 10-27-2020, 01:15 PM #4
Bueller? Bueller? Bueller?
Well, if nobody knows what to do...burn it to the ground? LOL Just Kidding. At least this tells me that its not very common to have this issue.
Old 11-06-2020, 04:04 AM #5
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Sorry about the delayed response. I don't get on the forums as much as I used to in the past couple years.
Basically it's a very generic DTC even from Toyota's side that boils down to "Steering Angle Sensor has an issue."
IF your powers & grounds on the sensor are all good, then more than likely the sensor decided to give up the ghost. I can't tell you why it did, they just seem to decide to die one day (I have had brand new Tacomas come in with dead ones before randomly.)
Another thing you can try is IF it does take a Zero Point Calibration and you can drive it a short while before the DTC resets, you might be able to use an ABS capable scantool to see the datalist for the module. That way, if the Steering Angle Sensor is stuck at a specific measurement and won't change no matter what it's more than likely the sensor (there's some exceptions to this, but generally you'll see like -1040° or 632° on the datalist and it won't change when you drive/turn the wheel.)
BlackWorksInc is offline   Reply With QuoteReply With Quote
angle , c1231 , malfunction , sensor , steering
Steering Angle Sensor Replacement pb&j 3rd gen T4Rs 6 05-21-2021 05:33 PM
HELP: Steering Angle Sensor - Traction Light and Powersteering Light Jayhawk5G 5th gen T4Rs 0 09-17-2020 11:05 AM
Air-Fuel Ratio (A/F) Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) vipblades 3rd gen T4Rs 33 10-25-2014 11:06 AM
Fixes for sensor malfunction on '88 T4R Dan98034 Classic T4Rs 7 04-20-2013 03:18 PM
