Old 10-26-2020, 07:27 PM #1
Lifesfordeath Lifesfordeath is offline
Lifesfordeath is on a distinguished road
Interior Map, Headlights Flicker while running
Hello,
I replaced my alternator recently and belt due to my headlights and interior map lights flickering while it’s running at idle as well as going down the road at highway speeds. The problem still persists
Battery voltage shows @ rpms
13.94-14.03 @ idle
14.09-14.12 @ 1500
14.12 @ 2k
14.14 @ 3k
Not sure what gives here. Have checked my grounds (have big 3 done) and all cables are tight and grounds are clean metal. Checked positive cables and those are tight as well.
The lights don’t dim while the truck is off. Does this rule out the battery?
Thanks for the help...I’m going crazy here lol
Lifesfordeath is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 07:51 PM #2
JH225 JH225 is offline
JH225 is on a distinguished road
I wish I had an answer to your problems. I had this on a previous vehicle and never could figure out what was causing it. I did big 3 and then some on that vehicle, and I went through multiple batteries and alternators in the time I had the vehicle. All produced the same effects.
Best of luck!
JH225 is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 08:37 PM #3
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
I had something like this on my 99 4runner after swapping in a new alternator. It also happened while driving, and then my lights all turned off. It turned out to be an obscure issue to do with the 3 wires that control the alternator. The white wire, that monitors the voltage had corroded and was intermittently connecting, causing voltage spikes until the wire finally broke and my voltage spiked to 16v.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 09:17 PM #4
triethylborane triethylborane is offline
triethylborane will become famous soon enough
A flicker suggests a bad connection, ground, a light control module (though Im not sure if 4th gen has this) or possibly a switch with a connection issue. But if it is a dimming issue:
It is likely as @Drcoffee said, sounds like the voltage regulator. Id rule out the battery.
Could take it to autozone or whatever for electrical system testing, Ive never done it though.
triethylborane is offline   Reply With QuoteReply With Quote
battery , cables , interior , map , tight
LED Headlights and Interior Lighting? SurrenderToThePhlo 3rd gen T4Rs 4 01-12-2017 11:29 AM
Headlights flicker/dimming when i brake. bigskyeric 4th Gen T4Rs 0 11-16-2013 09:46 PM
headlights dim interior lights... itgirl 5th gen T4Rs 33 02-10-2011 07:31 PM
HID Flicker sant6236 4th Gen T4Rs 1 02-08-2010 03:48 PM
HID FLicker sant6236 4th Gen T4Rs 1 01-25-2010 10:38 AM
