Old 10-26-2020, 09:24 PM #1
aglast15 aglast15 is offline
aglast15 is on a distinguished road
Burnt Out Dome Light Negative Ground
Ok, I have to admit my stupidity here.
I rigged up some rock lights on my rig and was trying to wire the ground into the dome light ground so that they would come on at the same time and act as courtesy lights.
In a rush to finish the project I connected the POSITIVE live wire to the NEGATIVE ground wire used to turn on the dome lights.
I quickly realized my error but it was to late. I'm pretty sure I burnt out the ground wire that is turned on by the ECU. I inspected all the wire I could get to but I don't see any burn out parts and I don't get a negative reading with a multimeter.
Did I fry something in my ECU or did I burn out a wire and I just can't find it?
Any insight would be welcome!
aglast15 is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 09:53 PM #2
triethylborane triethylborane is offline
triethylborane will become famous soon enough
What happens when you put the key in and move it to the ignition positions? Does it start?
triethylborane is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 10:18 PM #3
Yes of course the car turns on. Everything else still works perfectly. The dome lights just don't come on automatically anymore.
Old 10-26-2020, 10:31 PM #4
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
There’s a 10A fuse for the dome light in the engine compartment. It’s a fuse for a lot more than just the dome light, so it might not be blown.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 11:55 AM #5
Then you answered your own question as to whether the ECU was toast.
Old 10-27-2020, 01:23 PM #6
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
There could still be one burnt out circuit in the BCM, unfortunately. Not saying it is but it's possible. I'd pull it out, give it a smell test and if necessary, open it up and have a peek inside. Those circuits are so delicate some service manuals will actually tell you to touch metal inside the car before touching the computer to discharge any static electricity from your body, that could spark and damage them.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
dome , ground , lights , negative , wire
DDM Light Socket Burnt Out octanejunkie 3rd gen T4Rs 5 11-11-2017 12:35 PM
empty gas light burnt out? drawsprocket 4th Gen T4Rs 3 03-27-2017 12:53 AM
Dashboard 'Drive' Light Burnt Out 01sr54x4 3rd gen T4Rs 21 02-27-2013 09:46 PM
a/c light burnt out nc211 4th Gen T4Rs 2 01-27-2009 11:22 AM
Burnt out my Instrumental Panel Light, Help! jakewarm3 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 12-31-2006 04:38 PM
