Originally Posted by Syr4RinNC
So the coils/ springs on a 5th gen give about a 1in lift to 4th gen and the trd has roughly another inch lift so you’re looking at maybe 2 inches. You’ll have to read through converting 4th gen to 5th gen struts, but yea you’ll need a bigger lower mount hole for the bushing and then you’ll only fit 5th gen struts from there on out
Yeah it looks like the top plate on the front struts in actually the same and there is some mods needed to change the lower mount or some people say you can get a different bushing pressed into TRD Fox's. Thatnks for the info on the ride height. I think I'm gonna go for it and see what happens. I'll document the setup in a updated thread once I'm all finished. Cheers dude!
Originally Posted by montijo505
I believe you also have to grind down either the LCA bucket or the actual lower mount on the strut to squeeze it in there. I would look at some dobinsons rear springs. They have lots of different height options.
Good luck fitting 35's with minimal lift, but don't let me discourage you. You'll need a body lift and aggressive BMC as well as extended rear bump stops. Post results!
Sent from my SM-G986U using Tapatalk
I've got some Rough Country coils sitting in storage I might use for test fitting and then get some Dobinson's ordered once I've got it all mapped out.
You can fit 35's if you're willing to cut. I don't think ride height actually has anything to do with fitting bigger tires. Just maybe makes parts of the process a tad easier. Wish me luck! I'll update when it's all done.
