Originally Posted by T4R916
I have SCS SR8 with 285/70/17 falken wildpeak on with 3 inch icon lift with JBA UCA. Tires are rubbing on control arm when making u-turn and i already have BMC. My question is....can i use Spider Traxx wheel spacers to correct the rubbing issue on the control arm?
What's the wheel width and back spacing on your SCS wheels? Not real sure why your SCS wheels would have you rubbing your control arms even with JBA UCA's. If they are rubbing the UCA's for sure, then some spacers will definitely stop that, but you may have to trim a little plastic as mentioned above.
Sent from my SM-G950U using Tapatalk
