Old 10-31-2020, 03:00 AM #1
T4R916 T4R916 is offline
T4R916 is on a distinguished road
33’s rubbing on UCA
I have SCS SR8 with 285/70/17 falken wildpeak on with 3 inch icon lift with JBA UCA. Tires are rubbing on control arm when making u-turn and i already have BMC. My question is....can i use Spider Traxx wheel spacers to correct the rubbing issue on the control arm?
T4R916 is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 03:03 AM #2
montijo505's Avatar
montijo505's Avatar
JBA are notorious for this issue. You can grind them or yes install spacers. Keep in mind spacers will likely cause you to rub more on fender liners and bumper.
Sent from my SM-G986U using Tapatalk
Old 10-31-2020, 07:42 AM #3
T4Jumper's Avatar
T4Jumper T4Jumper is offline
Real Name: Greg
T4Jumper will become famous soon enough
T4Jumper's Avatar
Real Name: Greg
I needed to use wheel spacers to avoid rubbing on my jba UCA as well. If you already have the bmc you should be alright. Might have to trim some plastic, but nothing crazy.
2016 Trail - Sold
2023 TRD Off-Road - RSG Sliders, RCI Skids, 2 inch Bilstein/OME lift, 285/70/17 Cooper STT PRO, Prinsu Full Length Rack
T4Jumper is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 08:57 AM #4
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
What's the wheel width and back spacing on your SCS wheels? Not real sure why your SCS wheels would have you rubbing your control arms even with JBA UCA's. If they are rubbing the UCA's for sure, then some spacers will definitely stop that, but you may have to trim a little plastic as mentioned above.
Sent from my SM-G950U using Tapatalk
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 01:59 PM #5
Thanks guys i will try the spacer method and i forgot to mention in my previous post that I have Demelll front bumper i believe the offset is -12
Old 10-31-2020, 03:28 PM #6
montijo505's Avatar
montijo505's Avatar
Get some bora spacers, the spidertraxx are too wide with that offset wheel. Maybe a 1/2 inch spacer at most.
Old 10-31-2020, 06:01 PM #7
I dont see a 0.50 spacers but i see a 0.75. So a 1.25 will be too much for the SCS wheels..?
Old 10-31-2020, 08:17 PM #8
montijo505's Avatar
montijo505's Avatar
Get the. 75 the 1.25 el make you rub the punch weld and firewall
Old 10-31-2020, 08:30 PM #9
montijo505's Avatar
montijo505's Avatar
The .75 is less likely but still possible. Post results of what you figure out.
Old 11-01-2020, 03:37 AM #10
Hmmm...maybe i’ll just go with SPC control arm. Kinda dont like the spacers idea but thats more money to spend over spacers. 🤔🤔
Old 11-01-2020, 11:27 AM #11
montijo505's Avatar
montijo505's Avatar
I ran a similar wheel with 33's and SPC and no issues.
arm , bmc , control , rubbing , uca
285 70 17 rubbing yuletscha 5th gen T4Rs 17 12-24-2017 12:16 AM
help with rubbing johnwoo 4th Gen T4Rs 11 07-09-2016 08:29 PM
"Rubbing" sound... But not rubbing? A.Wilson013 3rd gen T4Rs 24 10-13-2015 10:38 PM
All Pro UCA's rubbing. Scramble 3rd gen T4Rs 40 06-23-2015 05:17 PM
HElp im Rubbing!! KoNEJO 4th Gen T4Rs 4 02-26-2011 10:19 AM
