Old 11-01-2020, 01:58 PM #1
Ctullu's Avatar
Ctullu Ctullu is offline
Ctullu is on a distinguished road
Ctullu's Avatar
Question Regear question (Center diff/transfer case low gears)
I couldn’t find a solid answer to this anywhere.
Is it possible to change the gears for 4lo on a v6? I am going to be regearing my diffs at some point (hopefully soon) and want a better gear ratio for off-roading in 4lo (somewhere in the range of 40 to 50:1 final ratio in first gear). I want to keep my hi gears stock for highway driving. Is this possible, and if so does anyone sell the gears required for this?
I am running 33s on a stock drivetrain right now on a 2004 4-speed trans (the one with a dip stick).
Thanks for the help! You guys rock!
2004 SR5 with 195K miles.
Icon Lift, 33" Patagonia MT tires, ARB Bullbar, Coastal Offroad rear bumper.
Ctullu's Build Threadl
Ctullu is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 03:56 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Probably need a Marlin crawler or something similar. Marlin makes auxiliary gearing for off road applications.
Old 12-08-2021, 11:20 PM #3
mvainer mvainer is offline
mvainer is on a distinguished road
Replying to pop this up - Marlin, Atlas and some others sell transfer cases for Toyota, but for the life of me I can not figure out if any of the regeard ones (4.7 or more) are available for 5th gen and if so what should one buy and whom to consult on this? Doesn't it make the most sense to regear the transfer case vs the differential?
mvainer is offline   Reply With QuoteReply With Quote
Old 12-09-2021, 08:09 AM #4
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
This a thread that might answer your question.
Changing the gearing for "L" (transfer case re-gearing) | IH8MUD Forum
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 12-09-2021, 10:06 AM #5
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I haven't seen anyone swap gears in our 120 series transfer cases. Tacoma's have the option of Marlin's dual case 'Taco Box' that bolts between the factory transfer case and transmission, but it won't work in our trucks, there isn't enough room, the fuel tank is in the way. Most FJ's and 4Runners I believe use an aftermarket Atlas t-case.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 12-09-2021, 04:54 PM #6
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
If you were trying to run 37's.. or were even on 35's and did some serious rock crawling I would say it would be worth entertaining the idea. 33's with a regear (4.56 i'm assuming? ) will be more than enough for what you'll ever need. Your money is better spent on lockers, at least for the rear, you'll see a heck of a lot more benefit to that over significantly lower gearing in 4lo.
just my opinion.. but I am on the v8 and low end torque is pretty phenomenal even on 35's with only 4.56 gearing.
aemravan is offline   Reply With QuoteReply With Quote
Old 08-18-2022, 08:58 PM #7
ricerulz ricerulz is offline
ricerulz is on a distinguished road
I would love to make the 4 low in these trucks actually low without giving up the stock setup so I hope you find something for both of us.
ricerulz is offline   Reply With QuoteReply With Quote
4lo , gear , gears , ratio , stock
Diff and Transfer Case oil change at 40-45k? JLM3rd 5th gen T4Rs 49 03-08-2018 10:53 PM
Transfer Case & Center Diff Question? Grimarine 3rd gen T4Rs 23 11-27-2014 10:22 AM
Diff/Transfer Case Oil Question DC runner 4th Gen T4Rs 5 05-26-2012 09:07 AM
2003 4runner transfer case gears crushed - engine check? jackalexander General Discussions 1 02-02-2012 06:00 PM
diff oil and transfer case oil pls help reidy404 Maintenance/Detailing 2 02-22-2007 08:46 AM
