Old 11-01-2020, 07:44 PM #1
inglysh inglysh is offline
inglysh is on a distinguished road
Transmission shifts fine - gear selector issues
2006, v6, 140k.
I can select drive and 4th gear, but...
The gear selector cannot be physically moved to 3rd gear.
It just won't budge. It can be moved into drive, and then 4th, D, N, R, and P, but no other positions.
I feel like I've encountered this before and that there is a "secret handshake"... but I cannot recall/don't know if I'm misremembering.
Any thoughts?
inglysh is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 09:22 PM #2
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Originally Posted by inglysh View Post
2006, v6, 140k.
Any thoughts?
Oh boy. This is a common problem. There is a pin that rides in a track as you move the shifter through the different positions. The track it rides in is plastic and wears down and develops a ridge that the pin can't get past. Do a search for shifter on here and also one for floppy shifter. There are several threads on here. The issue you now have may change to a floppy shifter if you try to force it where it doesn't want to go. The housing that the pin fits in will break off. The easiest fix, also the most expensive is to just go ahead and replace the whole shifter with a new one. I wouldn't recommend getting a used one. I tried that and the one I got was as bad as mine. They can be repaired if you're really handy. I fixed mine by removing the spring that applies pressure on the pin that rides in the track. The I cut the spring, thereby shortening it and greatly reducing the pressure on it. It works fine but it actually moves a little too easy from position to position. Anyway, you should be able to find a lot of info from the threads that are on here. Good luck
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
4th , drive , gear , moved , selector
A/T first gear rough shifts? PNW yota 3rd gen T4Rs 5 11-04-2013 09:06 PM
Gear selector gone bad tnark 4th Gen T4Rs 4 12-26-2012 01:08 PM
Transmission Issues - Getting out of first gear and others Smack2k Problems & Warranty Issues 0 01-16-2012 04:48 PM
Transmission Issues - Getting out of first gear and others Smack2k 3rd gen T4Rs 0 01-16-2012 04:21 PM
Gear selector loose woff32 3rd gen T4Rs 1 05-06-2010 11:40 AM
