Old 11-03-2020, 01:06 PM #1
drtyjerz47 drtyjerz47 is offline
drtyjerz47 is on a distinguished road
Oil all over inner wheel
Hey gents,
I got oil all over the inside of my driver front wheel. I need help narrowing this down so I'm not buying parts I dont need. I'm in WI and I'm fighting the clock before it gets real cold out.
Let me know what you think. The brake fluid isn't low so I don't think it's that
I though wheel bearings were grease not fluid so my last guess would be the xreas.
Thanks for your help
Oil all over inner wheel-16044230175561939650053142092269-jpg  Oil all over inner wheel-16044230410028384829605010072656-jpg  Oil all over inner wheel-16044230839514472916757558178079-jpg
[B] 2004 Sport edition V8 Natty white-
Sold: 1999 T4R Limited Imperial Jade mica, 2017 T4R SR5P magnetic gray metallic
drtyjerz47 is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 01:54 PM #2
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Its cv axle grease. The boot is leaking. The boot is split closest to the hub
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 01:54 PM #3
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Two things I would do to identify the source location:
1: Assuming the oil was covering surfaces under the truck as you're driving, crawl under and move toward the front until you see no oil-covered parts. The oil will always drift rearward as you drive, so once you see dry, you'll know it's not further forward.
2: Spray brake cleaner to get rid of the oil you see. It'll dry everything off. Then take a short drive, park it again, and look for wet spots.
I had caught a tiny grain-of-sand size bit of debris under my oil filter gasket once, and it was easy to spot the leak once I dried everything off with brake cleaner.
Hope this helps!
thennen is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 02:16 PM #4
montijo505's Avatar
montijo505's Avatar
While the boot is split, I don't think that's CV grease everywhere. Looks really watery. When my boots have split (happened a lot before using Toyota boots) it was big globs of thick black grease. It was mainly.on the spindle near the boot and piled on the LCA right under it. Not saying it can't be, just not my experience.
If definitely check the brake hoses/fittings and the xreas stuff too. Looks like it's coming from somewhere high because it's all over your caliper too.
Sent from my SM-G986U using Tapatalk
Old 11-03-2020, 04:24 PM #5
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd has a spectacular aura about Bassturd has a spectacular aura about
Bassturd's Avatar
I would also second that it’s CV grease. There’s some pretty noticeable globs in your pics. It will appear to bleed onto the surrounding parts and start to collect dirt and debris into it. Normally if it’s a break fluid leaking out of either the steel line, rubber hose, or caliper your would feel it in the pedal or at least notice a slight drop at stops. Hope this is helpful and good luck.
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 05:51 PM #6
do you use synthetic oil?? ya know that stuff is super slick & will make every 4runner leak... scotty kilmer said so. might want to check your head gaskets too...
Old 11-03-2020, 05:55 PM #7
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
It looks too thin to be CV grease, like montijo said. I can't see if thats a torn boot close to the wheel bearing side or just fluid residue giving that appearance. Wipe it with your finger and see what color it is, the outer CV grease is think and dark black, see pics. If its a light brown, then could be the xreas fluid. I don't have xreas on mine since I have an SR5, but based on how its all over the shock, that would be my guess
y=mx+b is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 09:39 AM #8
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Though your boot is split, most of what can be seen is not grease.
Try to find the highest wet spot and start eliminating possible sources.
could be a ruptured PS line, but from the image below it looks like your XREAS line has a weep/leak either at the fitting or at this kink:
Oil all over inner wheel-2020-11-04_7-34-49-jpg
UrbanRunner651 is offline   Reply With QuoteReply With Quote
brake , fluid , low , oil , wheel
Stock wheel & suspension with wheel spacer: 275/60R18 or 265/65R18 tire? skywalker1020 4th Gen T4Rs 5 12-13-2023 08:35 PM
WTT: 2019 SR5 wheel-tires (250 miles) for Black wheel-AT Tire combo ToyoRuski For Sale: Suspension/Wheels/Tires 0 11-09-2018 07:54 PM
FS: 5th Gen N-FAB Wheel-to-Wheel Nerf Bars $300 Michigan (Metro Detroit / Boyne Area) Boyne4R For Sale: T4R Items 0 08-22-2017 01:13 PM
Unknown Creak from front right wheel, not ball joints, wheel bearing?? ryanbigcheese Classic T4Rs 2 02-23-2014 12:47 PM
