Old 11-04-2020, 12:33 PM #1
klavender1 klavender1 is offline
klavender1 is on a distinguished road
School me on the necessity of adjustable sway bar links
While still waiting on my Dobinsons IMS lift to come in, I'm trying to get everything squared away. I need new sway bar links anyways. So I will be getting a 3" front (with added weight of a bumper and winch) and 3" rear to maintain rake.
Will 2nd gen rear sway bar links suffice? Are longer sway bar links necessary for the front? I don't plan on removing my sway bars.
klavender1 is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 01:01 PM #2
lord rigatoni lord rigatoni is offline
lord rigatoni is on a distinguished road
i would recommend getting a pair of adjustable end links. when you lift a vehicle you change the geometry and articulation of the suspension from how it is supposed to perform on stock ride height which is what you want but the problem is the front end links are not long enough to compensate for the added articulation of the suspension. having adjustable end links allows you to change the torsion rate of the sway bar which allows you to balance out the added body roll you get when lifting a truck
lord rigatoni is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 02:55 PM #3
pauldub pauldub is offline
pauldub will become famous soon enough
If you lift the rear 3" you will likely have nearly zero droop unless the shocks are very long. If they are very long, you'll likely need to lower the bumpstops so that the shocks don't bottom out on compression.
pauldub is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 02:59 PM #4
Why do you think that you "need new sway bar links anyways"?
Old 11-04-2020, 04:09 PM #5
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Longer links will allow the sway bar to rest in a normal position. As the truck gets lifted, the sway bar's core gets further from the link's mounting points, rotating the "arms" that reach out from the core (mounted on the axle), up to the links. These arms are designed with a specific angle in mind... shortening them or lengthening them (via rotating the bar) changes the force applied to the sway bar, and probably the angle the force is applied as well.
So several things can happen... shortening the arms would increase the tension/compression in the end links (same weight of truck but shorter lever), causing the links to break. changing the angle of the force application to the bar can cause the bar to break off because the bar bends during articulation rather than twists, as its supposed to.
Yeah, one would generally want to keep the bar as it was designed to work. So lifting up a bunch, longer links would be ideal if you want the sways to work properly and not rip stuff up. I've seen a bunch of threads about broken sway bars and that longer links fixed the problem.
Adjustable links and adjustable bars are slightly different thing... they let you tune the aforementioned lever arm length to get different ride characteristics. But it's the same idea I suppose.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 04:15 PM #6
I've searched before asking and know there was a person on here building them. Not sure if he still is. But do you have a recommended links that don't break the bank? Dobinsons wants $150 just for the rear!
Would 2nd gen rear links suffice for my lift?
The boots are torn. Also one of those, while it's torn apart, might as well replace these small parts.
Old 11-05-2020, 12:56 AM #7
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
2nd gen for the rears are the cheapest way to go.
Sounds like anything longer just get in the way.
Front use a sway bar "relocate", couple of blocks that move front bar down and forward slightly.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 11-05-2020, 01:06 AM #8
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Remove the front sway bar, you don't need it. I haven't had one since I swapped out the dead XREAS on mine at the beginning of the year.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 11-05-2020, 09:45 AM #9
How did this affect your on road handling? I like to take corners faster than a typical SUV.
Of course it would be easy to remove it just to see for myself.
Old 11-05-2020, 10:01 AM #10
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I did exactly what BackOff described here for the front and rear on my 4Runner with a 3” Toytec/Bilstein lift. Cost me around $60.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 11-05-2020, 10:50 AM #11
Forum148 Forum148 is offline
Forum148 is on a distinguished road
This is the website of the guy who makes them on here. If you are interested in purchasing a pair it might be worth waiting because he has new sealed heim joints coming out in five weeks or so.
Overland Custom Design
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 09:36 AM #12
mcaninch35 mcaninch35 is offline
mcaninch35 is on a distinguished road
Thanks for this- makes a lot of sense!
mcaninch35 is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 10:39 AM #13
This is what I'm going to go with. Except I'm going to remove the front bar. If I don't like it removed, I'll get new standard replacement links and a relocate kit.
Old 11-09-2020, 06:12 PM #14
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Since you like to take fast corners, I can guarantee you'll hate the amount of body leaning with no front sway bar!
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 08:23 PM #15
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
If you spend most of your time on-road you may like the front swaybar on.
If you like to play off road... ditch the front sway bar.
These things ride better overall without the front swaybar and the suspension works better. IMO
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
bar , front , links , rear , sway
Adjustable Sway Links (?) Devbot 3rd gen T4Rs 18 09-01-2020 09:08 PM
Dobinsin’s Adjustable Rear Sway Bar Links - Installed Louisiana Overland 5th gen T4Rs 8 06-30-2019 03:38 PM
Anyone running Dobinsins adjustable rear sway links? Louisiana Overland 5th gen T4Rs 0 06-17-2019 08:24 PM
SOLD FS: 3rd Gen MStudt Adjustable Sway Bar Links - Orange County, CA - $150 zacattack20 For Sale: Suspension/Wheels/Tires 4 09-12-2017 12:13 AM
Adjustable Sway Bar Links BlacknTan 5th gen T4Rs 1 03-09-2015 07:07 PM
