02-09-2009, 12:53 PM
Side Mirror Vibration?
Let me start by saying that I picked up my pre-owned '06 4Runner this weekend and it seems to be the most solid SUV I've ever driven. I pretty much love everything about it, other than one 12V outlet in front!
One thing I noticed is that my driver side mirror has an annoying vibration while driving. It's an annoying in the sense that the image in the mirror is constantly moving, making it a bit more difficult to see. Is there a way to tighten up this mirror assembly so that it doesn't do this? I'm not quite sure if its the glass or the whole housing and my passenger side mirror doesn't seem to do it as bad (which may be due to the distance that I sit from the mirror).
Thanks so much for the help,
Wes
02-09-2009, 01:02 PM
Real Name: Adam
Real Name: Adam
Re: Side Mirror Vibration?
Wes
I'd guess your passenger mirror is doing it almost as much as your driver mirror but due to distance you don't notice. Mine both do it too. Its not a HUGE amount of movement but even a millimeter in both directions is a lot when you are driving and need that image its reflecting to be stable. I've checked mine multiple times and its nice and tight though.
2005 V8 Sport Edition 4x4 | Icon Stage 2 | Total Chaos LCA's | Blackvue DR900X-2CH Dashcam | Pioneer AVIC-W8600NEX
02-09-2009, 03:26 PM
Well I went for a drive with the window open and held the mirror. It's actually the whole mirror housing that is vibrating and not just the glass. What keeps this housing tight on its mount (where it pivots)?
Thanks,
Wes
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
03-06-2009, 03:51 PM
Anyone have an answer to this? I was checking this out and the driver mirror is noticeably more loose than the passenger side. Is there any way to tighten the mirror at its folding pivot point?
Thanks so much,
Wes
2018 TRD ORP - Sold
03-06-2009, 05:10 PM
Banned
Banned
Thanks so much,
Wes
I have noticed the same thing; however, it only occurs when there is a crosswind or just windy conditions in general. I have driven 100 w/ no wind and the mirrors havent moved.
I also notice that its only in the driver side as well.
03-06-2009, 06:45 PM
With mine it happens no matter what the wind is like.
Thanks,
Wes
2018 TRD ORP - Sold
03-13-2009, 10:01 AM
So judging by the lack of information on tightening up the mirror, that may not be a user serviceable component. The FSM I downloaded only shows how to remove and install the mirror so that may be the case or I simply don't have the complete FSM. If that's the case, looks like I may have to purchase a new side mirror to fix it. Anyone know how much a new side mirror costs and do they come painted?
Thanks so much,
Wes
2018 TRD ORP - Sold
03-13-2009, 10:15 AM
Mine do it too but only when the wind is behind you.
03-13-2009, 02:02 PM
My Sequioa used to do that. I found two number two phillips screws at the bottom of the mirror housing and I tighted these up and the problem was fixed. It returned again after 6 months though, but I found the screws loose again. I then bought lock washers from the hardware store and removed the screws one at a time, added the lock washer, tightened them back up, never a problem again. I am not sure if the 4runner works the same way, but stand on your head and look up at the bottom of the mirror housing and see if there are screws.
BTW, mine only did this on the driver side. I never had any trouble with the passenger side. I figured it was because the driver door was used more and closing it caused the screws to work loose over time.
RickC
2003 Toyota 4runner Sport V6 4x4, Daystar 2.5/1.5, Enkei ST6 18x8.5, Toyo Open Country AT2 285/60/18, Scion FRS Touchscreen head unit with NAV and backup camera, LEDBARZ 41" light bar.
03-13-2009, 03:33 PM
Was there a cap or anything covering the screws? I don't remember screws being there (I may not have looked close enough) but I'll take a look when I get home from work.
Thanks so much,
Wes
2018 TRD ORP - Sold
03-13-2009, 03:34 PM
No there is no cover over them, but they were recessed. But like I said, mine was a Sequoia and they may be made different.
RickC
09-16-2009, 11:43 PM
so, after detailing my rig tonight, I noticed the passenger mirror assembly is loose...drivers side is tight...has anyone come up with a way to tighten these? I have already spun the mirror in and out and cannot see a screw or adjustment...please advise.
16 Classic Silver SR5 Premium 4 x 4
09-17-2009, 12:09 AM
mirror vibe
I had a mirror vibrating and found that the mirror was actually broken, nothing to tighten up. Sucks $300 for a new Toyota one. Good luck.
Jet
02-10-2011, 04:15 PM
damn it!! I have the same issue on both by mirrors, 2006 with 66k on it.. annoying as hell
04-14-2011, 11:57 PM
Same exact problem here as KP Texan. I looked closely and do not see any screws. Something has to be loose somewhere. Anybody with any other ideas ?
DJJ
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
