11-05-2020, 07:01 PM
Tire Inflator gun - free flow
Hey All
Not sure if this is the right place to post this question, but I am looking for a tire inflator gun BUT that is free flowing when the trigger is NOT depressed. Then when pressing the trigger, it stops the flow.
Is there such a thing? I've been googling around but can't find anything and/or don't know what terms to look for.
The reason I need the reverse operation is because I use a Viair 300p and you cannot use the traditional guns the stop flow, unless you turn on/off the compressor.
I want it to be free flowing but then I can momentary stop the flow so that the pressure gauge can read the tire pressure.
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
11-05-2020, 09:08 PM
Real Name: Elliott
Real Name: Elliott
Wouldn't take more than a couple seconds to blow up that hose or even break that pump... Why not tie in a pressure switch? Or just mount it and plumb it to a tank and then do a switch...
As to your question, no such device exists, at least that I'm aware of and I've been wrenching for a while.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
11-05-2020, 09:58 PM
yeh i was thinking that. so actually, im building a hose with a T at the far end with a 50psi safety release valve. Then gonna use a regular inflator with trigger. That should work ok yeh?
11-05-2020, 11:14 PM
Just use a pressure switch to shut off the compressor.
11-05-2020, 11:24 PM
Would that go onto a T fitting and then wire the pressure switch inline with the + lead?
The viair 300p is a tankless compressor. Sorry if I'm not fully understanding.
11-06-2020, 09:41 AM
Real Name: Elliott
Real Name: Elliott
You would want to tee it in at the discharge outlet of the pump, that way you don't have super long wires going to the switch, you would wire it in series to the on/off switch. The really high-end expensive compressors have this already built in
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
