11-05-2020, 07:35 PM
Real Name: Isaac
Real Name: Isaac
Tow hitch differences between the GX and 4runner, why?
So I have just purchased another gx470, this one however does not have the towing package, and I am looking to install a tow hitch on it. I know the 470 and the 4th gen 4runner share the same frame and chassis so why are the part numbers different 228-89440(50) for the 4runner, and 228-60540 for the gx, they both require the center spacer plate to make them work with the factory class IV hitch. So why when I look these two part numbers up in the parts que does it give two different part numbers with two different fitments. What am I missing.
-at first I thought maybe it was because of the GXs air suspension but then I remembered that limited 4runners also had air suspension so that can't be it as the 4runner hitch doesn't exclude the limited...
Sent from my Pixel 5 using Tapatalk
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
11-05-2020, 07:43 PM
If I remember correctly the V8 4th gen had a different tow package than the V6. The GX is a V8? Maybe that's the difference?
Sent from my SM-G986U using Tapatalk
11-05-2020, 08:37 PM
Real Name: Skip
Real Name: Skip
The Toyota part number you posted for the V8 tow hitch only fits the 2003 through 2005 T4R, 2006 through 2009 has a different part number for the V8 tow hitch, I unfortunately can't recall the part number for the later 4th Gens, so maybe that's why the numbers aren't matching, but on the other hand one is a Toyota part number and the other is a Lexus part number so that also could be the reason for different part numbers, even if the part is exactly the same.
2004 Limited V8
11-07-2020, 12:42 AM
Real Name: Isaac
Real Name: Isaac
I found the reason for the difference and it's silly but makes complete sense. It's because of the hitch cap/plug, the 4runner one is going to have the Toyota logo on it and the GX hitch is going to have a cap/plug with a Lexus logo. It's silly but that is the reason for the different numbers. When a part is exactly the same like say relay or a wiper motor they have the same part number, Lexus and Toyota. But whenever there is some sort of physical or other actual difference there is a part number difference.
11-07-2020, 12:53 AM
Real Name: Skip
Real Name: Skip
I figured it was a Logo/Toyota/Lexus thing!
What year GX did you get?
2004 Limited V8
