11-06-2020, 01:10 PM
Roof weatherstripping
I was at the car wash and the blower blew this part off of one side. Is anything supposed to actually connect it? I just slid it back into the channel. What's it called (in case it flies out on the highway and I need to find another one). And lastly, do I really need it? Thanks.
Sent from my SM-G950U using Tapatalk
11-06-2020, 03:11 PM
At $60 ish each, I put mine in with a few dabs of RTV to 'glue' it in place. Weatherstrip adhesive would work well too.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
11-06-2020, 03:40 PM
Real Name: Todd
Real Name: Todd
The channel weather strip on mine came out on one side after a wash as well. I pulled the other side out when I got home. Haven't put them back in. With the roof rack in place, this will not cause any leaks to worry about.
If you want to replace any of the roof weatherstripping, here are the part numbers.
Windshield and roof mouldings
1x 75531-35110 - MOULDING, WINDSHIELD, OUTER UPPER
1x 75548-35010 - FASTENER, WINDSHIELD OUTSIDE MOULDING, RH
1x 75549-35010 - FASTENER, WINDSHIELD OUTSIDE MOULDING, LH
1x 75533-35050 - MOULDING, WINDSHIELD, OUTSIDE RH
1x 75534-35030 - MOULDING, WINDSHIELD, OUTSIDE LH
2x 75557-35010 - MOULDING, ROOF DRIP SIDE FINISH, CENTER NO.2, RH/LH
1x 75553-35010 - MOULDING, ROOF DRIP SIDE FINISH, REAR, RH
1x 75554-35010 - MOULDING, ROOF DRIP SIDE FINISH, REAR, LH
2x 75561-60030 - CLIP, ROOF DRIP SIDE FINISH MOULDING
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/70/17 Toyo ATIII on Sequoia rims, Sherpa rack, Coastal front bumper, custom rear bumper
11-06-2020, 04:52 PM
What website are you using for the pns? Thanks.
11-06-2020, 05:13 PM
Awesome, thanks guys!
11-06-2020, 05:28 PM
Amazon.com: TOYOTA Genuine 75553-35010 Roof Molding: Automotive
Found the RH and would guess the LH is at same price cheap and OEM
 Toyo is my Name and My Ride
11-06-2020, 05:43 PM
Originally Posted by toyoman25
Great price, several years ago, not so much.
2009 SR5 V6 ---RIP
11-06-2020, 07:52 PM
Real Name: Todd
Real Name: Todd
Toyota - Toyota Parts and Accessories - Official Online Store
11-06-2020, 10:50 PM
I just realized both of mine are gone lol. Guess I'll add that to list of things to order soon.
Current - 21 TRD ORP, Matte Gray TRD PRO wheels on 285/70/17 BFG KO2, Bilstein 5100’s OME 885/889, Spc UCA
Old(still in the family) - 07 Sr5 V6 2wd, Bilstein 5100's, Ome 884/895e, TRD ORP wheels, SPC UCA and CBI front skid plate.
07-24-2022, 06:28 PM
All of these seem to be parts for 2006-2009 according to online shops. Did they fit your 2003 ok?
07-25-2022, 05:05 PM
Real Name: brian
Real Name: brian
You don't need new ones! I had the same issue. There is no glue or double sided tape needed. When I had my 4runner painted, I took it completely apart. With the roof rack off I did a test fit and they were tight. You don't have to take the roof rack off, only one side at a time. Slide the moldings in from the rear. The rear moldings behind the roof rack slide out. Get some dielectric grease or any non petroleum grease. Just clean out all the grooves in the channels (while your in there), and slide the moldings in under the bump outs in the channels in the roof.
Mine have been tight since I put it back together ( about 5 months ), and multiple car washes. They were installed from the factory with no tape or glue.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Nitto grappler g2 275 55 20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, General Grabber ATX 275 55 20, Magnaflow Exhaust,, Powerstop brakes, sport hood.
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back exhaust, 4Runner XP rims, Michelin Defender LTX 275/55-20,sport hood.
07-26-2022, 02:21 PM
Both of mine have been gone for a long time now... seems like this is quite a common thing to lose. Has anyone heard of leaking due to these being gone? Seems to be pretty well-sealed without them...
If I were to put new ones on, I'd probably use some silicone to ensure they don't fly away again.
05 v8 Limited - Eibach Pro Lift Kit 3.75" Front, 1.75" Rear - JBA High Caster UCAs - Coastal Offroad High Clearance Rear Bumper w/ Dual Swingarms - Toyo Open Country ATIII 285/70/17 - Bronze Raceline Clutch 17x9 Wheels - Custom Gray Raptor Liner Paint - Sony XAV-AX3000 - Front Sway Bar Delete - Extended Rear Sway Bar Links - Rear Diff Breather - RCI 1/4" Aluminum Front Skid - Cali Raised DOM Rock Sliders
08-02-2022, 08:00 PM
I don't have any leaks and just an open channel where those pieces go on my 2005
10-24-2022, 05:43 PM
I was searching through the forums, and this seemed to be the most related to the topic. I recently bought a used 5th gen 4Runner and noticed a piece was missing on the front windshield. Does anyone know what the part number is for the piece in question? The picture shows one side with the piece and the other without it.
10-24-2022, 08:07 PM
Real Name: Skip
Real Name: Skip
You would be better off and get better help from 5th Gen owners by posting in the 5th Gen forum section, this is the 4th Gen section.
2004 Limited V8
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
