12-22-2022, 06:02 PM
#16
Real Name: Todd
Real Name: Todd
Originally Posted by five-alive
All of these seem to be parts for 2006-2009 according to online shops. Did they fit your 2003 ok?
2003-2009 are the exact same body style. Only major differences are headlights, grill and slight differences in front fenders body wise, for the most part. So yes, they fit perfectly.
*corrected some information*
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
12-22-2022, 06:26 PM
#17
Real Name: Skip
Real Name: Skip
Originally Posted by xtremewlr
2003-2009 are the exact same body style. Only differences are headlights, grill and hood body wise, for the most part. So yes, they fit perfectly.
The head lights aren't the only differences, the wheel wells/fenders are different as well, the 2003 to 2005 are more flat at the top of the wheel wells, the 2006 2009 are rounded at the top of the wheel wells, the cladding is also different, not that any of these differences affect the hood, the hoods as mention are the same shape other than a scoop on the Sport model.
2004 Limited V8
12-23-2022, 11:18 AM
#18
Real Name: Todd
Real Name: Todd
Gotcha. The point was tho, that the roof is the same through all the years and that the part numbers I listed will work regardless of year.
01-30-2023, 09:07 PM
#19
Real Name: Skip
Real Name: Skip
Originally Posted by CelticRunner
I recently noticed leaking just above my left shoulder on the drivers side. I’ve been inspecting the door seals and none seem damaged (plus the drips are not from the door but a couple of inches further inside, up high).
I only recently realized I’m missing this piece. Gonna order a new replacement and hope this fixes it.
These are just trim pieces, they will not stop a leak, your leak is another issue!!
2004 Limited V8
01-30-2023, 09:23 PM
#20
Originally Posted by yourfriendcasey
Both of mine have been gone for a long time now... seems like this is quite a common thing to lose. Has anyone heard of leaking due to these being gone? Seems to be pretty well-sealed without them...
If I were to put new ones on, I'd probably use some silicone to ensure they don't fly away again.
Thanks, you caught me before I could delete. Further research and perhaps it’s just a coincidence that this weather strip is also missing. I’m wondering if it’s a seal gone bad under the front driver side roof rack Mount (stock room rack, never modded, and just started, possibly die to age)
06 SR5, 190k miles (just breaking it in)
06-10-2023, 09:53 PM
#21
The price in 2023 is outrageous, $80+ from any dealer, for a single piece
06-13-2023, 09:28 PM
#22
One of mine is gone too. Didn't even notice it for a while. I've done the roof rack delete and have no leaks without them there. It might collect more leaf debris though
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
