Originally Posted by greenman91
P2714 = "Pressure Control Solenoid" Story: Driving on the highway. Truck wouldn't shift from 4th to 5th. I turn it on the next day and I get an engine light along with VSC and VSC Trac. Put in my scanner and got a P2714 code and P0776 pending code. Rewind 10k miles. Did a trans fluid drain and refill, along with a new filter. Old fluid looked fine and there were no metal shavings on the magnet. Hoping it's just the solenoid. Confirmed the part number with a toyota dealership today. Going to have my mechanic replace the solenoid and see what happens. Fingers crossed.
Hi, Greenman,, did you replace Solenoid?? should I change transmission filter and fluid first??did this fix problem and eliminate code P2714? same issue with my 2006 v8 4runner, my car only has 65k miles,,I welcome your reply..thanks
