11-09-2020, 07:01 PM
CRAPPOLA, broke a front bump stop bolt
I got a little too excited while swapping out the front bump stops with Wheeler bump stops and broke off one of the mounting bolt. I'm not looking forward to drilling out this bolt head since it lives inside a cavity.
Let me know what creativity some of y'all have come up with to remedy this situation.
Thanks.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
11-09-2020, 07:05 PM
Following purely for amusement, sorry lol. Although now I think about it, I have some rear bump stop extensions I need to drill a bolt out of. Dang.
Sent from my SM-G986U using Tapatalk
11-09-2020, 07:58 PM
Good luck - invest in a while quality drill bit
11-10-2020, 05:34 AM
Real Name: Seth
Real Name: Seth
I wonder if you could follow the same protocol as drilling/tapping the front skid plate bolts out to M10 hardware?
Both of mine snapped off, for the meantime Im using generic ones in some holes I found to the rear of the LCA. They work, but meh.
2006 Shadow Mica SR5 v6 1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
11-10-2020, 12:00 PM
Part of me wants to use the Plasma cutter to enlarge the hole then get mid evil with things
11-10-2020, 03:04 PM
I've pretty much done away with all the frame mounted threads at this point and use rivet nuts. You can get a tool and some stainless metric rivet nuts off Amazon for not a whole lot of money. You'll need a drill 3mm bigger than the bolt diameter. So if its a 8mm diameter bolt, you need an 11mm drill bit
When I need to get rid of the frame mounted nuts , i like to heat it up with my torch and then blop it with my air hammer. If it's not available, a good coue whacks with a drift punch ought to do the trick.
11-11-2020, 04:31 PM
I have all rivnut tools but drilling out this broken bolt is a royal PITA due to its location. I'm not sure which way I'll go but I'll post up pics after I'm done.
11-11-2020, 06:18 PM
Definitely gonna have to move the LCA out the way. At least remove from spindle, loosen cam bolts and swing down.
I watched a video the other day of someone using a small torx bit to extract a bolt. Drilled a hole a smidge smaller than the bit, then hammered in the bit and took it slow. I am sure much heat and penetrating oil was involved. Good luck.
11-13-2020, 12:55 PM
Not a fun job that's for sure! Hope it all works out for you.
