View Poll Results: Type of oil used
Synthetic 59 86.76%
Synthetic
59 86.76%
Conventional 6 8.82%
Conventional
6 8.82%
Synthetic blend 3 4.41%
Synthetic blend
3 4.41%
Voters: 68. You may not vote on this poll
Old 11-10-2020, 12:42 PM #1
What oil do you use in your 4runner?
In light of recent comments by our resident oil expert/mechanic/SK fanboy, I thought id start a thread for what type of oil people use in their 4runners. Feel free to comment the mileage & weight you use, & if you have leaks due to the oil alone.
Apparently, using synthetic oil will cause leaks in all engines, head gasket issues & engine damage all because synthetic oil is super slick & is cheap! the only way to avoid this is to use 10/40 conventional oil... but you will still have "1 drop per week!" Oh & by the way, your water pump will only last 4 years! & you should use T-IV trans fluid in your WS specd transmission! No, im not making this up!
Old 11-10-2020, 01:01 PM #2
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Haha love it. 134k 5w30 synthetic. switched at 113k. The previous owner did all oil changes at the dealer, so Im guessing it was their conventional oil. no issues as of yet
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 01:02 PM #3
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I have always used Mobil 1 5w-30, regular at first but now high mileage and extended interval. 2004 V8.
In the 13 years Ive owned my 4Runner, it has never lost a drop of oil. Every time I change the oil, its still full. I have never added any oil between oil changes, and there has never been even one drop on the ground under the engine. I dont have a skid plate, so its not like its leaking but I cant see it.
Im also on my original water pump. I did get the tranny rebuilt at ~175k mikes, but I had been towing for about 10 years.
My 4Runner has been very reliable, as was a Sienna minivan, a Corolla 4-dr and a Corolla All-Trac wagon I owned many years ago. Non-Toyota, a Volvo 240 wagon was also very reliable. Ive never owned an unreliable car that I can remember. Nothing American and nothing Italian, French, English, etc. First car ever was a VW bug from the 1970s, super reliable.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 01:04 PM #4
hstexan's Avatar
hstexan hstexan is offline
hstexan will become famous soon enough
hstexan's Avatar
I just use conventional and change it out every 3500-4000 miles--I've never had an issue and as far as the maintenance on this 4R goes I abide by the idea of "if it ain't broke, don't fix it."
Edit: I just rolled over 191K a few weeks ago
2006 Toyota 4Runner Limited 4x4 V6 Shadow Mica Sold
Dobinsons Suspension 300/221 Front & 505/637 Rear | FN Wheels f(x) pro | BFGoodrich KO2 275/70/17 | Front Runner Slimline II | ARB 2000 | Gobi Ladder | Treeline Outdoors Tamarack RTT
hstexan is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 01:13 PM #5
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I switched to Shell Rotella Gas Truck Synthetic 5w-30 at 209k miles and haven't noticed any leaks as a result of the change. I change at 4k so the blackstone numbers all come more or less the same interval. My passenger side valve cover had a slow leak before the switch, and still does afterward. Stick shows around 1/8" below top line at the change interval.
The best part is the head gasket was leaking slightly before the change to full synthetic :P, which was one of his arguments for using conventional. My last oil analysis on the blend showed 50ppm Potassium and 28ppm Sodium in the oil, although the reservoir hasn't dropped much since I marked it about 8 months ago.
I don't have a problem with anyone running synthetic or conventional. My main thing was why that guy was telling us ours should be leaking oil, when several of us had mentioned we made the change without any issues. Also kept using the term "slippery" to try and describe oil, which was amusing. I do feel partially responsible for the mess, since I was the first to take a jab at scotty in his original thread lol
y=mx+b is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 01:17 PM #6
P_nlsn's Avatar
P_nlsn P_nlsn is offline
Real Name: Parker
P_nlsn has a spectacular aura about P_nlsn has a spectacular aura about
P_nlsn's Avatar
Real Name: Parker
I use Valvoline High Mileage Maxlife
I lose some oil through leaks/burning, but on 17 year old factory seals with 313k miles, that's more than expected - and the loss is barely any compared to what I think it should be
4wd V6 '03 Sport w/ 340k miles (175k engine swapped @ 326k) // 3" Suspension Lift + 3" Body Lift on 35" K02's
@toto.runner // Build Thread // Engine Swap Write-Up
P_nlsn is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 01:48 PM #7
Urbanite Urbanite is offline
Urbanite is on a distinguished road
I have yet to do my first oil change as my truck is new to me and currently has 81K miles. The person who sold it to me used conventional oil, but I plan on using synthetic in the near future, and I'm crossing my fingers. My last truck, Infiniti QX4, started leaking at the main seal when I changed to synthetic. So, I'm hoping this doesn't happen to this truck; I love seeing a dry engine bay;)
So, I'm very curious to see how others respond to this thread.
Urbanite is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 01:53 PM #8
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
V8
Swapped to synthetic at 130k miles and haven't noticed a drop at over 160k.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 02:11 PM #9
allcaps55 allcaps55 is offline
allcaps55 is on a distinguished road
I use Liqui Moly long time high tech 5W-30. Get free lifetime replacements from FCP Euro and truck seems to drive great.
allcaps55 is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 02:47 PM #10
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Older cars usually have to use conventional motor oil instead of synthetic motor oil. Switching to synthetic can cause engine leaks or engine damage.
What Are the Risks of Switching to Synthetic Oil in Older Cars? | YourMechanic Advice
Captsolo is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 02:58 PM #11
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Captsolo,
Did you read the article your linked too?
Let me quote Tips for Using Synthetic Oils in Older Models
When using the term older refers to cars, it means those manufactured before 1990 or so. The risk with these models is that the seals, gaskets, and other components often arent as tight as with newer models
Last I checked 4th gen T4R are 2003 and newer. The seals that we used back then were crappy cork rubber seals that needed the crud to plug up leaks. Modern seal dont fail like that any more.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMPhows it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 03:06 PM #12
& there he is with more of his links he found on google! LOL! you should read your own links before posting, did you miss the part that says "older" vehicles mean prior to 1990?? thats 30+ years ago! is your 4runner a 1990?? & the "damage" they mention is only if you run low on oil & dont check it!!! synthetic oil itself does NOT cause engine damage, einstein!
When using the term €œolder€ to refer to cars, it means those manufactured before 1990 or so. The risk with these models is that the seals, gaskets, and other components often aren€™t as tight as with newer models. Because synthetic oil does a better job of cleaning out sludge, it could remove deposits that are acting as seals. This could result in leaks that cause the engine to burn oil and require you to monitor your oil levels and replace it more often. If you don't, you risk damaging the engine or other components.
It€™s not accurate to say that you should never use synthetic oil in an older car. In fact, Castrol EDGE High Mileage is a synthetic oil designed specifically for high-mileage cars. If the car has been maintained and is in excellent running condition, the synthetic oil may protect the vehicle and prolong its life. Also, anytime you change from conventional oil to synthetic oil, always make sure to change the oil filter with every oil change.
Old 11-10-2020, 03:58 PM #13
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Here we go again, lol. I've only had my runner for about 24k miles and I've run Valvoline Maxlife full synthetic 5w30 the whole time. I didn't bother asking the PO what they were running because I don't subscribe to the theory that you can't or shouldn't switch to synthetic. I run what I believe in. Doesn't matter to me what they ran in it. It has a very minor leak on the rh side of the engine that I honestly haven't taken time to diagnose. However, it was like that when I bought it and it doesn't appear to have gotten any worse. Also, I have 287k on it so a very minor leak doesn't bother me too much. One day when I have time I'll fix it. And when I say minor, I mean it's never enough to hit the ground and it doesn't seem to be causing the level to drop. It drops about 1/2 a quart between changes which I do every 5K. I never have to add between changes. With 287K I find that totally acceptable. I figure if it was a domestic vehicle it would be losing more than that by the time it had 75K on it, lol.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 06:00 PM #14
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
There’s a 4th possibility, switching back and forth between dino & syn. That’s not a planned thing necessarily but I’ve done it numerous times. The engine doesn’t obsess over this stuff the way we owners do.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 06:20 PM #15
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Conventional...as recommended by the dealership.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
10/40 , drop , leaks , oil , synthetic
