Old 11-11-2020, 07:33 PM #1
T4R916 T4R916 is offline
T4R916 is on a distinguished road
Dobinson rear LT vs Toytec Superflex
I currently have superflex rear springs with bilstein 5100 but want to change to Dobinson rear LT. is the superflex consider long travel springs? If they are i was just going to replace my rear shocks with dobinson long travel instead.
T4R916 is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 09:37 PM #2
pauldub pauldub is offline
pauldub will become famous soon enough
The shock length is what determines your travel, not the springs. You need to choose the spring rate you want for the load you carry and then choose a spring length to give you the ride height that you want. The shock length decision interacts with the ride height decision or you can easily end up with no droop and all up travel. The following short article will help you decide how much up and down travel you want to end up with:
Go Fast Suspension Design Article | AccuTune Off-Road
What are you really trying to achieve?
pauldub is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 10:27 PM #3
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
dobinson is like a chinese knockoff. lol
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 11:56 PM #4
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Don't you mean Toytec is a Chinese knockoff?
Dobs has the best budget LT kit on the market.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 12:19 AM #5
montijo505's Avatar
montijo505's Avatar
The short of it is you'll need longer springs and extended bump stops to make LT shocks work. Get a hold of @Crikeymike and he can help with part numbers and such. He's also running a sale through November.
Sent from my SM-G986U using Tapatalk
Old 11-12-2020, 01:24 AM #6
Thanks guys!
Old 11-12-2020, 02:39 AM #7
andreylights's Avatar
andreylights andreylights is offline
andreylights will become famous soon enough
I went from 5100+spacer lift to Dobinsons LT, so let me know if there are any particular questions I can may be helpful with.
07 SE V6, Front: Dobinsons LT GS59-220 + C59-302 w/ ICON UCAs;
Rear: GS59-575 + C59-677V w/ ICON Trailing Arms; PCK;
Coastal-Offroad bumper and sliders; ASFIR aluminum skids;
255/80r17 Falken AT3W on Toyota Trail edition wheels;
andreylights is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 10:22 AM #8
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Dobinsons Spring & Suspension™ established in 1953, pride themselves on having the world’s largest range of 4x4 spring and suspension componentry.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 10:25 AM #9
Crikeymike's Avatar
Crikeymike's Avatar
Yes, they're a progressive spring and has some really good flex. I'm not sure what the limit is though with the length of shocks that can be ran with them. Best to give them a call and see if they have that info for you, then you can choose a longer shock without changing the springs.
The LT shocks though require longer brake lines, bump stop extensions, and preferably upper and lower trailing arms to rotate the pinion angle a bit and gain axle housing clearance from the shock at full droop. They can make contact with stock arms, and the upper arm on the driver's side can also contact the fuel tank too.
Old 11-12-2020, 09:52 PM #10
04rnr's Avatar
04rnr's Avatar
Just because they say that on THIER website, doesn't make it true. They are still, a Chinese knockoff IMO
2007 Sport.
Old 11-12-2020, 09:53 PM #11
04rnr's Avatar
04rnr's Avatar
Do you work for them?
2007 Sport.
Old 11-12-2020, 10:26 PM #12
montijo505's Avatar
montijo505's Avatar
He does and is upfront about it. Nothing to hide. I also tagged him and said as much.
Old 11-12-2020, 11:05 PM #13
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 10:34 AM #14
Crikeymike's Avatar
Crikeymike's Avatar
Yes, and my name is Mike Tomczyk, what's your name? You work for Toytec, right?
No worries there, just don't go slandering stuff that you have no idea about, as spreading misinformation about a product isn't the right thing to be doing on forums.
Old 11-13-2020, 11:06 PM #15
04rnr's Avatar
04rnr's Avatar
so, you're a vendor, makes sense why you keep trying to talk them up.... My name is Ric, I help run a warehouse.
Ive been wheeling long enough to know what works and what doesnt, what will last and what wont,,been in business long enough to know quality products when I see them. Am I an expert? NOPE.
Good luck with
2007 Sport.
dobinson , long , rear , springs , superflex
WTB Superflex/Metaltech/Dobinson long travel coils ianf5 For Sale: Suspension/Wheels/Tires 7 07-10-2018 09:19 PM
3rd gen Toytec Superflex Rear Coils Bryan1 For Sale: T4R Items 1 04-07-2013 11:46 AM
Can the ToyTec Superflex rear coils support a rear steel bumper? JustSomeName 4th Gen T4Rs 6 10-15-2012 01:40 PM
