Originally Posted by Mr_Dobalina
I used the search function but the posts were all very old. I have a 2007 4Runner that needs font struts and rear shocks replaced. Does anyone have a good recommendation on what and where to order from?
Daily driver, seldom off road use, and don't want to lift it.
What are your thoughts on the complete strut assembly? Lat time I used a spring compressor to replace struts I felt like I was holding a land mine in my hands the whole entire time.
This seems like a good deal but there are no reviews:
2007 Toyota 4Runner (without X-REAS Suspension System) Front & Rear Complete Shock Assembly & Shock Absorber Kit 8 Piece Set
I would be grateful for any suggestions.
Thanks!
I put that set on my 03 4wd Limited about a month ago.
Don’t think I was replacing the originals (had Gabriel’s on it), but the springs looked like the OEM springs.
Mine is mainly a daily commuter on paved roads, mix of country roads, freeway, and city streets.
And I wanted something inexpensive.
No leaks on the old ones, but I was bouncing excessively over bumps/holes and lots of body roll.
These springs are definitely firmer (more coils) than what I took off, but still plenty comfortable for my tastes.
But the ride and handling is way more controlled than with the old ones, and a lot less continual bounce over bumps.
Have one big bump/dip on my commute that I used to bounce all over the place if I hit it going fast. Now it is a single bump and then flattens right out at similar speeds.
And I drive it hard when I hit some curves, and noticeably less body roll and easier to track on my line when really committed and pushing hard in a curve.
Obviously can’t speak to longevity though, will have to see how long they last and if they were worth the lower price.
Probably not as good as some of the name brand options, but was a definite improvement over the old/worn ones.
