Old 11-12-2020, 12:55 PM #1
Mr_Dobalina Mr_Dobalina is offline
Mr_Dobalina is on a distinguished road
Need Recent Recommendations for Replacement Shocks and Struts
I used the search function but the posts were all very old. I have a 2007 4Runner that needs font struts and rear shocks replaced. Does anyone have a good recommendation on what and where to order from?
Daily driver, seldom off road use, and don't want to lift it.
What are your thoughts on the complete strut assembly? Lat time I used a spring compressor to replace struts I felt like I was holding a land mine in my hands the whole entire time.
This seems like a good deal but there are no reviews:
2007 Toyota 4Runner (without X-REAS Suspension System) Front & Rear Complete Shock Assembly & Shock Absorber Kit 8 Piece Set
I would be grateful for any suggestions.
Thanks!
Mr_Dobalina is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 01:29 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
ads2539 will become famous soon enough ads2539 will become famous soon enough
ads2539's Avatar
If you don’t want a lift and it’s your daily driver and seldom off-road, the suspension you’re looking at should be fine.
Getting the struts pre-assembled makes it a lot easier to replace the front suspension.
2004 Limited 4WD 179k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 02:02 PM #3
pauldub pauldub is offline
pauldub is on a distinguished road
My bet is that you will see no difference with the old shocks you have now versus the new set that you're looking at. In other words, the cheap new ones probably are not better than very used OEM shocks.
pauldub is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 02:08 PM #4
You don't need to use a spring compressor to remove the springs from the struts. You can do it on the vehicle very easily and safely.
OME Install - no spring compressor - Toyota 120 Platforms Forum
Leave the sway bar connected and you won't need to support the hub as he does in the link.
Old 11-12-2020, 03:42 PM #5
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough
I installed a brand new suspension from a new 5th Gen 4R TRD Off-Road. It required two minor modifications. I've never been so happy with a comfortable suspension as I am with this one. My 4R has a smoother, softer ride than my friend's Lexus GX.
These suspensions are all over Craigslist around here for about $150. Taken off brand new 4Rs due to aftermarket upgrades.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 04:46 PM #6
Well, looking at an upgraded package - Bilsteins - but sold out....
Bilstein Height adjustable front and matching 5100 Rear shocks
Old 11-12-2020, 04:46 PM #7
MikeinNH67 has a spectacular aura about MikeinNH67 has a spectacular aura about
I did the same on my rig, the set came off a 2019 4R I think with hardly any miles on them. Maybe $100 on E-bay just gotta watch. Like night and day and the front is a decent height now.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 11-12-2020, 06:42 PM #8
I'd put the 5100 shocks in the "cheap new ones" category, but not nearly as cheap as the ones that you were looking at. Since you don't want a lift, maybe just go with KYB or Bilstein 4600. Look at what Rockauto has to offer. I have 5100s on my 3rd Gen and I wouldn't buy them again.
Old 11-12-2020, 07:46 PM #9
SeanWN86 SeanWN86 is offline
SeanWN86 is on a distinguished road
Invest some time cruising the local classifieds. Find somebody that's selling their take offs. Easy to find low mileage units. With a little shopping maybe you can snag up a trd pro takeoff(that's not ridiculously overpriced).
Then you've satisfied your needs, kept budget low and retained OEM reli/durability.
Thanks!
SeanWN86 is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 01:18 PM #10
Thanks! - I just ordered the 4600's.
Old 11-13-2020, 01:28 PM #11
Renol Renol is offline
Renol is on a distinguished road
I have 5100s so this may not apply to you, but check to make sure you actually have enough stud from the rear shock. Mine had barely enough stud left to get the nut started without some effort.
Renol is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 08:51 PM #12
PC1978 PC1978 is offline
PC1978 is on a distinguished road
Thanks!
I put that set on my 03 4wd Limited about a month ago.
Don’t think I was replacing the originals (had Gabriel’s on it), but the springs looked like the OEM springs.
Mine is mainly a daily commuter on paved roads, mix of country roads, freeway, and city streets.
And I wanted something inexpensive.
No leaks on the old ones, but I was bouncing excessively over bumps/holes and lots of body roll.
These springs are definitely firmer (more coils) than what I took off, but still plenty comfortable for my tastes.
But the ride and handling is way more controlled than with the old ones, and a lot less continual bounce over bumps.
Have one big bump/dip on my commute that I used to bounce all over the place if I hit it going fast. Now it is a single bump and then flattens right out at similar speeds.
And I drive it hard when I hit some curves, and noticeably less body roll and easier to track on my line when really committed and pushing hard in a curve.
Obviously can’t speak to longevity though, will have to see how long they last and if they were worth the lower price.
Probably not as good as some of the name brand options, but was a definite improvement over the old/worn ones.
PC1978 is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 11:53 AM #13
firebirdguy is just really nice firebirdguy is just really nice firebirdguy is just really nice firebirdguy is just really nice
there are qute a few recent threads on replacing shocks, even though you wnet with the 4600's teh KYB are excellent replacements & are far better than any worn out 13 year old used shocks. they great great reviews & are priced right & come with new springs installed.
also i know this is a nit pick but 4runners do not have struts, they just are a coil over shock.
good , holding , shocks , struts , time
Looking for Recommendations for Shocks and Struts Tstebb10 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-03-2018 07:14 PM
Replacement of Front Struts, Rear Shocks, Rear Springs, and Bushings foyaboya Engines / Suspension / Wheels / Tires / Audio / Accessories 14 01-17-2016 10:01 PM
Door lock actuator failure after recent replacement AppSt92 4th Gen T4Rs 2 01-05-2016 02:41 AM
97 Shocks and struts replacement question fblainen11 3rd gen T4Rs 28 11-23-2015 10:44 PM
Shocks/Struts replacement vegimate Maintenance/Detailing 0 04-15-2006 01:42 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
