Old 12-04-2020, 12:15 AM #31
RobD RobD is offline
RobD will become famous soon enough RobD will become famous soon enough
I guess I'm fortunate. My brother works for an auto parts store up here in the frozen tundra and they carry Koyo. With his discount, the bearing cost me around $75 and $18 at the u-wrench to use their press. Dealer wanted $375 for the bearing.
RobD is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 12:57 PM #32
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
If I ever have to do bearings again I am going that route. Press out the old, press in a new.
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 10:58 AM #33
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Talking
I had a front WB fail on my 2005 150,000 miles 4runer. A mechanic knocked out bearing and the cost for job was $300+ It took hours of labor.
The right way to do this job is buy the complete assembly and just bolt it on and off.
Amazon.com: FKG 515040 (4WD Only) Front Wheel Bearing Wheel Hub Assembly fit for 10-16 Lexus GX460, 2003-2016 Toyota 4Runner, 03-09 Lexus GX470, 07-14 Toyota FJ Cruiser, 05-14 Toyota Tacoma, 6 Lugs With kit: Automotive
The one above comes with 1 year warantee.
2WD 3-Year Warranty
Amazon.com: MACEL 515040 2WD Only Front Wheel Bearing and Hub Assembly Compatible with 03-16 Toyota 4Runner, 07-09 Toyota FJ Cruiser, 05-17 Toyota Hilux, 05-19 Toyota Tacoma 6Lugs w/ABS: Automotive
Captsolo is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 04:56 PM #34
MikeinNH67's Avatar
MikeinNH67's Avatar
I went with Beck/Arnley, the install was actually pretty simple. If you stick a piece of 1/4" angle iron on each side of the hub so that the 4 bolts push against the outer hub when loosened, it pushes it right out quite easily. I also like how the bottom swing arm unbolts without pulling the ball joint. I also replaced the dust shield while in there as there was nothing left to it. Pisser is that the old bearing appears that it was not bad, it looked fine when I separated it with my press and I still have the noise. Contemplating doing just the bearing on the other side as maybe that's where the noise is coming from. I hope it's not the front diff but I bought gear oil today for that.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-20-2021, 05:22 PM #35
MikeinNH67's Avatar
MikeinNH67's Avatar
So I finally got to replacing the passenger side front wheel bearing today plus the rusted dust shield. No more noise except for tire hum. I went with the BECK/ARNLEY 0516444 from Rockauto as it has a Koyo bearing in it and comes with seals for just under $80. Worth having someone press them onto your hub than buying the China made assembly in my opinion. I have a press so wasn't too hard to do. The old noisy bearing was an unknown brand and whoever replaced it in the past did not put the seal that is between the bearing and hub. People wonder why I do my own repairs.
So this closes out my bearing saga for now. If the drivers side China bearing starts getting noisy I will go the same route I did for the passenger side.
Mike
03 4runner Limited
Old 02-08-2021, 04:09 PM #36
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
I was checking rockauto and noticed they have a brand Im not familiar with BCA but made in IL USA. Cost $49 and uses a Japanese NSK bearing.
Has anyone used these before.
Aftermarket wheel bearing?-e7174fcd-cf37-4dce-8e48-3c01a938546a-jpg
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 04:57 PM #37
MikeinNH67's Avatar
MikeinNH67's Avatar
I noticed the Rockauto picture for Centric also showed the NSK bearing. NSK is supposed to be good so I hear.
Mike
03 4runner Limited
Old 02-09-2021, 04:05 PM #38
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
you can also get this. this is what i use and seems to be okay at a decent price. this is for a 4th gen 4runner - 4x4 only with hub and bearing.
4Runner / Tacoma / FJ Cruiser - Wheel Hub Bearing Assembly - (4x4) - with ABS | eBay
4r-4ever is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 04:22 PM #39
Drcoffee's Avatar
Drcoffee's Avatar
You can get a full hub bearing assembly which makes the job quick for one wheel but after buying two it gets expensive quick. Years back I bought a harbor freight 20 ton press. Since then I replaced the 4 wheel bearings on my lexus is300, the rear bearings on my kids ford explorer and my FJC 2007 front bearings and probably the fronts on this 07 4runner. The press has saved me thousands of $$. Well worth the $140 I paid for it.
Old 02-09-2021, 04:36 PM #40
MikeinNH67's Avatar
MikeinNH67's Avatar
I wanted the Japanese bearings which is why I went the route I did.
As for the press, I use my HF press more often than I thought I would. Quite useful.
Mike
03 4runner Limited
Old 02-09-2021, 04:56 PM #41
i like the japanese parts too. in my case, i had to get the cheap ones since i don't want to spend any more money with my old 4runner. i don't intend to drive it for road trips anymore since my rear upper control arm frame connection is so rusted there's a hole in it. i only use it for local driving, getting groceries or something or just a backup car. all my insurance are now liability so i don't pay much for insurance. i'm surprised after installing it 2 years ago, the bearing is still good. cheap parts doesn't mean bad parts.
Old 02-16-2021, 04:59 PM #42
MikeinNH67's Avatar
MikeinNH67's Avatar
Understandable but it wasn't that much more for the Japanese bearing assuming I was pressing it in. This is my daily driver and I have a plow on the front of it so want a quality bearing.
Mike
03 4runner Limited
Old 10-24-2021, 01:39 AM #43
maddss maddss is offline
Real Name: Scott
maddss is on a distinguished road
Real Name: Scott
Need for a 2005 RWD
Anyone heard of Detroit axle 950-004 ?
Amazon.com: Detroit Axle - 2WD Front Wheel Bearing & Hub Assembly Replacement for Toyota Tacoma PreRunner 4Runner FJ Cruiser - 2pc Set : Automotive
maddss is offline   Reply With QuoteReply With Quote
Old 12-28-2023, 09:18 AM #44
88skisupreme 88skisupreme is offline
88skisupreme is on a distinguished road
Thanks for the Rock Auto suggestion, I just bought a SKF replacement from NAPA, Rock Auto has them at less than half the NAPA price. I'm going to retrun the NAPA and get 2 from Rock Auto
88skisupreme is offline   Reply With QuoteReply With Quote
Old 12-28-2023, 03:05 PM #45
Drcoffee's Avatar
Drcoffee's Avatar
Honestly, I think the SKF unit uses a chinese bearing. Check for the ones stamped made in Japan like NSK. Much better quality.
aftermarket , bearing , nice , truck , wheel
Evap codes, needle bearing/wheel bearing and tires Johns06yota 4th Gen T4Rs 15 08-05-2018 11:10 AM
Wheel Bearing?? indy500 4th Gen T4Rs 38 11-15-2017 10:26 PM
help!!wheel bearing or carrier bearing or something else? sawguy 3rd gen T4Rs 7 05-06-2015 01:55 PM
Bad wheel bearing mlc2000 4th Gen T4Rs 23 04-14-2015 10:42 PM
Unknown Creak from front right wheel, not ball joints, wheel bearing?? ryanbigcheese Classic T4Rs 2 02-23-2014 12:47 PM
