Old 12-28-2023, 05:11 PM #46
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Originally Posted by Drcoffee View Post
Honestly, I think the SKF unit uses a chinese bearing. Check for the ones stamped made in Japan like NSK. Much better quality.
Last I looked I couldn't find any hub assemblies on RA that had something stamped on the bearing so I assume all Chinese now. They don't list the Centric ones I mentioned earlier in this thread and the Beck/Arnley no longer is stamped per the pictures.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-28-2023, 05:57 PM #47
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Buy the bearing and have a local shop press in your original axle stub. And it will be cheaper too. $55 for a bearing and $20 press work. Be sure they insert the bolts before pressing.
Aftermarket wheel bearing?-img_4617-jpg  Aftermarket wheel bearing?-img_4609-jpg
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 12-28-2023, 06:07 PM #48
MikeinNH67's Avatar
MikeinNH67's Avatar
My reply was for others, both my front bearings are on the new side with decent brands.
Mike
03 4runner Limited
Old 12-28-2023, 09:27 PM #49
locked up's Avatar
locked up locked up is offline
locked up is on a distinguished road
locked up's Avatar
Originally Posted by Honda pc View Post
When the slide hammer cracked I fell over!
locked up is offline   Reply With QuoteReply With Quote
Old 12-29-2023, 05:03 PM #50
MikeinNH67's Avatar
MikeinNH67's Avatar
That video is hard to watch for this shade tree mechanic. Yikes.
I replaced just the bearing on one and used a cheap HF press, not a hammer.
Mike
03 4runner Limited
Old 02-17-2024, 09:58 AM #51
Kokomodo Kokomodo is offline
Kokomodo is on a distinguished road
Part supply for knuckle/hub
My mechanic tried to press the bearing out of the hubs on my '99 4R 4WD with ABS. He could not get them out, and ended up damaging one of the hubs or knuckles, I'm not sure which. I'm looking for a quality supplier for the knuckle and hub. Driver and passenger side.
Apologies for the zombie thread...apparently I cannot post a new thread until I reply to enough posted threads. I'm trying to find the closest subject.
-Kokomodo
Kokomodo is offline   Reply With QuoteReply With Quote
Old 02-17-2024, 10:30 AM #52
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
-Kokomodo
You replied to a topic in the 4th Gen forum section, you would most likely get better answer if you posted/replied in the 3rd Gen forum section.
2004 Limited V8
Old 02-18-2024, 01:36 AM #53
Njdor Njdor is offline
Njdor is on a distinguished road
I purchased the SKF hub a year and a half ago and was able to confirm with an SKF engineer I work with that it is an SKF bearing assembly.
I wanted to go the Koyo route since it’s the oem bearing, but it was so much cheaper to do the skf route that I couldn’t justify Koyo + assembly costs (I didn’t have a press at the time)
I’d recommend the Koyo OEM route if you can, otherwise NTN and NSK are always great options. SKF is definitely a lesser bearing manufacturer, but for automotive bearings like these it isn’t that big of a deal.
Just make sure you’re buying from a distributor through legit channels. We’ve had huge issues with counterfeits in the supply chain lately.
Njdor is offline   Reply With QuoteReply With Quote
aftermarket , bearing , nice , truck , wheel
Evap codes, needle bearing/wheel bearing and tires Johns06yota 4th Gen T4Rs 15 08-05-2018 11:10 AM
Wheel Bearing?? indy500 4th Gen T4Rs 38 11-15-2017 10:26 PM
help!!wheel bearing or carrier bearing or something else? sawguy 3rd gen T4Rs 7 05-06-2015 01:55 PM
Bad wheel bearing mlc2000 4th Gen T4Rs 23 04-14-2015 10:42 PM
Unknown Creak from front right wheel, not ball joints, wheel bearing?? ryanbigcheese Classic T4Rs 2 02-23-2014 12:47 PM
