Originally Posted by Flybynight
I had them replaced as both were torn and I kept the old ones, I will re-pack and re-boot them if original OEM pieces but is there an easy way to check? I'll just toss them if they're aftermarket.
First, I'd look at the inner boot, and see if it has Toyoda (with the d, not t) on the inner boot. OEM inner boots also have 4 ribs, whereas some like napa maxdrive only have 3
From there, look at the shape of the inner joint bearing cup. The OEM body has a tulip shape should have the short grooves on the inner housing vs after market like napa maxdrive below often have longer grooves or none at all.
On Left: Napa maxdrive 3 inner boot ribs and long slots on inner housing for comparison. Right: O'reilly generic CV has a chonker of an inner joint housing and no slops.
And lastly, if you really want to get fancy, you can check the clamps. The OEM toyota axles use 4 different types of clamps at each boot connection, so you can check they are exactly as follows: Larger Inner, Small Inner, Small Outer, Large Outer
