Old 11-13-2020, 01:20 PM #1
Renol Renol is offline
Renol is on a distinguished road
Install flaps in wheel well after lift?
I lifted a few inches back in the summer and the front wheel well is awfully open to splash hitting the engine. What are some opinions on getting those rubber fender flaps and trimming to fit to control splash? With winter coming I'm thinking snow and water being a problem causing more rust than I already have.
Install flaps in wheel well after lift?-thumbnail_20201113_111357-jpg
Renol is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 02:09 PM #2
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Splash Shield for Toyota 4Runner Fender Liner Apron Seal Mud Flaps Flares 03-20 | eBay
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 02:22 PM #3
I've seen those. Just wondering what the consensus is on if it's worth it or not.
Old 11-13-2020, 02:34 PM #4
montijo505's Avatar
montijo505's Avatar
I got the rad rubber ones. More expensive but thicker than stock and come with fasteners.
Sent from my SM-G986U using Tapatalk
Old 11-13-2020, 02:36 PM #5
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
@Renol
I have the rear ward flap reinstalled on mine. It helps but lots of crap still getting up in the engine bay. Hood insulation is covered in mud splash from a water crossing last fall. After that I started thinking about creating new front splash guard flaps starting from the post and templates at DIY - Creating and Installing 4th Gen Wheel Well Splash Shields
My thought was to cut the top of the flap and holes then go put it in the truck and mark the bottom hole and edge position then reposition the template to match my marks and cut the bottom.
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 03:01 PM #6
montijo505's Avatar
montijo505's Avatar
These ones
4RUNNER (4th Gen 2003-2009) – Rad Rubber Design – FJ Fender Flaps, Toyota Engine Splash Guards
Old 11-13-2020, 03:10 PM #7
Based on the consensus it looks like yes they're worth putting on.
Old 11-13-2020, 03:34 PM #8
klavender1 klavender1 is offline
klavender1 is on a distinguished road
+1 for Rad Rubber. Initially I didn't want to spend $50 but I'm glad I did. Thicker that stock and should last a very long time.
klavender1 is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 03:42 PM #9
They're cheapies that'll do for a little while.
Rad Rubber are for sure better.
Definitely worth doing, especially on the passenger side of the v8 with the alternator location.
Old 11-17-2020, 09:52 PM #10
slow_sr20 slow_sr20 is offline
slow_sr20 is on a distinguished road
Get the RAD rubber design. Super nice quality. Improved function over stock. Install them & forget about it.l
slow_sr20 is offline   Reply With QuoteReply With Quote
Old 11-17-2020, 09:58 PM #11
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Buy some rubber sheet, make your own. It's rather easy and much cheaper.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 02:38 AM #12
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
2 summers with my DIY full coverage set did not see any noticed increase in engine temperature, scangauge2.
Did keep the engine bay a little cleaner.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
fit , flaps , splash , trimming , wheel
Would it be okay if I install both lift spacers and wheel spacers on my 07 T4R SR5? Nesian New Members 2 07-01-2014 02:04 AM
How to remove Mud flaps and wheel well trim!!! bmanbryce 3rd gen T4Rs 5 06-20-2013 06:54 PM
3rd Gen Wheel caps, bolts, Tape deck, mud flaps and Center Console FS masphx For Sale: T4R Items 2 08-23-2012 05:46 PM
4 wheel parts wont install my lift! 4MUDDER 3rd gen T4Rs 11 01-04-2010 03:23 PM
