Old 11-13-2020, 03:12 PM #1
gaswede gaswede is offline
gaswede is on a distinguished road
O2 sensor .xls overview
Can someone take a look at my attachments of my O2 sensor and Cat data?
One test at a time, I'm trying to systematically find a problem leading to my drastic loss in mpg and eliminate the fact that its all in my gearing.
I had to delee a chunk of the temp data just to shrink the file size but hopefully it will give a good idea of what going on.
gaswede is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 06:13 PM #2
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Hi.
Correct o2 sensor (post cat) function is pretty simple. The engine starts and begins to warm the cats, this causes an increase in voltage from .055V to a nominal .7V when fully warmed. After 60 seconds, the system goes into closed loop where the PCM spikes the fuel injector pulse width up and down to do 2 things. First, the stoichiometric ratio or lambda is modeled with the pre-cat sensor to provide rich/lean readings. Second, the changes in unburnt fuel through the system are measured by the post cat o2 sensor. These changes in fuel are not supposed to create drastic voltage changes on the o2 sensor due to the catalyst simply absorbing the extra oxygen. If the changes in o2 sensor readings match the changes in IPW the system will trip the catalyst efficiency obd2 code. Note that the o2 sensor changes are detected using PLL and not a lookup table - enabling phase transitions to appear like the cat is working (o2 sensor simulator).
If your cat is simply failing (or on the edge of failing), the PCM will retard the timing to burn extra o2 to keep the post-cat o2 sensor happy. Eventually, this will have no effect and the P0420/P0430 codes will be tripped. A way to "fix" it is to put on 2 spark plug defoulers to move the sensor nose out of the way of the exhaust stream. This does not improve mpg or hp. A better way is to put a small catalytic converter on the nose of only the o2 sensor to provide the PCM with data that shows that a brand new cat has been installed and advances the timing accordingly.
It looks like the mini-cat is what you are looking for. PM me for details.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 11-15-2020, 01:54 PM #3
Thanks for that great info man. This made perfect sense. Going over my data and with further research it looks like I’m an acceptable range. While my spark plugs are only 15k miles old, it may be time to pull and read them to make sure I’m not too rich.
Old 11-15-2020, 02:24 PM #4
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is a glorious beacon of light Drcoffee is a glorious beacon of light Drcoffee is a glorious beacon of light Drcoffee is a glorious beacon of light Drcoffee is a glorious beacon of light
Drcoffee's Avatar
Make sure your plugs are gapped correctly. It should be 0.043”. Mine came gapped at 0.37” and I had to reset them. A small gap will not give you a hot enough spark.
2007 4Runner Sport 4WD 4.0L 233,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
data , delee , file , gearing , sensor
ARB drawer install overview ArrArr 5th gen T4Rs 69 10-14-2025 02:09 PM
New C4 Hybrid Front Bumper Overview Battle Born Offroad 5th gen T4Rs 0 08-01-2019 12:36 AM
Overview of Orange County ethernectar So Cal 11 03-28-2012 04:31 PM
