Old 11-14-2020, 03:22 AM #1
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
Wierd steering
So recently I've had a strange issue with my steering... it goes like this.
Turning the wheel to full lock either left or right, I have 4 spots during that range that are extremely stiff, like PS isn't working.
Its like turn, easy. keep turning, super stiff. keep turning, easy. keep turning, super stiff.
Seems like there are 4 super stiff spots and I have no idea what is causing it.
The PS pump doesn't whine at all during the motion- could it be the little cardan joint on the steering shaft??
Any and all help is greatly appreciated.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 05:28 AM #2
sr5hi sr5hi is offline
sr5hi is on a distinguished road
toyota 4runnner steeirng shaft - Bing video
2003 SR5 V8
sr5hi is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 09:00 AM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Steering Column U-Joint
2005 4Runner Stiff Steering - Toyota 4Runner Forum - Largest 4Runner Forum
Greasing steering intermediate shaft U joints
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 01:21 PM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
There's one way to possibly check to see if the shaft is locking up/bad that you can try, spray the U joint on the shaft with a good penetrating/lubricating spray and see if the "stiff" areas go away, this will only be temporary and if so it will tell you that it's time to replace the shaft.
2004 Limited V8
Old 11-14-2020, 04:08 PM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I see you have an '04, I did my '03 a couple of years ago, the steering u-joint that is. It's a little bit of a pita, I finally had to put some heat to it to get it to break loose from the spline shaft.
Old 11-16-2020, 12:04 AM #6
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
Thanks man, I'll give that a shot! I've got some PB laying around somewhere.
Old 11-16-2020, 12:05 AM #7
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
Seems pretty inexpensive like $40 something to replace? It looks pretty rusty down there from the CO winters and such. I'm gonna spray it with some penetrant like @AuSeeker recommended then go from there! Thanks for your input!!
Old 11-16-2020, 02:29 PM #8
Bossman's Avatar
Bossman's Avatar
The OEM Toyota part is not cheap!
2004 Toyota 4Runner Sport Edition SR5 4.7L V8 4WD AT Steering Shaft. Shaft, Steering Intermediate, NO.2 - 4520335310 - Genuine Toyota Part
Old 11-16-2020, 04:43 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
That is exactly how mine was. As mentioned, soak the steering shaft u-joint with penetrant. It will loosen up but the damage is done and it will become loose in a few months. I installed one from e-bay, cheap to buy but a pain to replace and get lined up.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 11-16-2020, 07:50 PM #10
Real Name: Skip
Real Name: Skip
As Bossman mentioned the shaft is not cheap...not $40....but can be found for between $125 or so up to $200+.
McGeorge Toyota....
2003-2009 Toyota Lower Shaft 45203-35310 | Toyota Parts
Better deals if you do eBay....
Part Number: 4520335310 - Bing
2004 Limited V8
Old 11-17-2020, 04:16 AM #11
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
Thanks for everyone's input!!! Since my rig is kind of worn out, not super keen on blowing lots on OEM stuff. I mean, for suspension, engine, trans, and 4x4 stuff I'll do OEM, but for this I'll probably do the Amazon thing.
Amazon.com: Tecoom 45203-35310 Lower Intermediate Steering Shaft Assembly Steering Column w/U-Joint Fit for 03-09 Toyota 4Runner: Automotive
The thing is probably going to get parked pretty darned soon and used only for crazy bad weather/offroad camping trips.
Old 11-17-2020, 04:18 AM #12
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
First things first tho! Penetrant, here we come!
Old 01-10-2021, 09:28 AM #13
lj4r lj4r is offline
lj4r is on a distinguished road
has anyone experienced issues using the amazon or ebay parts vs OEM parts $35 vs $220 is significant, Job looks like a pain, some rust and limited access.
lj4r is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 10:51 AM #14
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
For me, there are three factors that decide OEM vs whatever brand:
1) How hard is the job? If it takes 30 hours to do, I don't want to risk the part breaking and costing me another 30 hours.
2) Is there a critical safety issue with it breaking? Example: my sway bar endlinks I'm building, if they break, it will not be fun driving home, but I won't be stranded and I'm unlikely to end up in a ditch as a result.
3) Is there a performance penalty to non-OEM? Example: CV axles. While Napa axles work, they tend to bind at full droop. For me that's a major issue.
In this case, both 1 and 2 are relevant. You are unlikely to have a steering lfailure that puts you in a ditch, so it is worth considering. However, how long is it going to take? Don't put the cheap part in unless you are willing to do it twice.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 06:16 PM #15
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
Do yourself a favor and get the yoke too. When I replaced my intermtant steering shaft I had to cut the yoke off. There are 3 bolts and those are probably corroded n place too. If I remember right they where 10mm.
Amazon.com: Dorman 425-476 Steering Shaft End Yoke for Select Lexus/Toyota Models: Automotive
Hunter61 is offline   Reply With QuoteReply With Quote
spots , steering , stiff , super , turning
wierd miss in 87 posigen Classic T4Rs 0 02-18-2013 02:56 AM
Wierd problem Paul H. Classic T4Rs 13 07-16-2011 03:18 AM
Wierd vibrations Tafty86 3rd gen T4Rs 1 05-19-2011 01:47 AM
wierd noise joey_magnelli Off-Roading 1 10-20-2006 12:48 AM
Wierd noise Toy-Yoda Problems & Warranty Issues 2 08-22-2006 08:55 AM
