11-14-2020, 03:22 AM
Real Name: Seth
Real Name: Seth
Wierd steering
So recently I've had a strange issue with my steering... it goes like this.
Turning the wheel to full lock either left or right, I have 4 spots during that range that are extremely stiff, like PS isn't working.
Its like turn, easy. keep turning, super stiff. keep turning, easy. keep turning, super stiff.
Seems like there are 4 super stiff spots and I have no idea what is causing it.
The PS pump doesn't whine at all during the motion- could it be the little cardan joint on the steering shaft??
Any and all help is greatly appreciated.
2006 Shadow Mica SR5 v6 1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
11-14-2020, 05:28 AM
toyota 4runnner steeirng shaft - Bing video
2003 SR5 V8
11-14-2020, 09:00 AM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
11-14-2020, 01:21 PM
Real Name: Skip
Real Name: Skip
There's one way to possibly check to see if the shaft is locking up/bad that you can try, spray the U joint on the shaft with a good penetrating/lubricating spray and see if the "stiff" areas go away, this will only be temporary and if so it will tell you that it's time to replace the shaft.
2004 Limited V8
11-14-2020, 04:08 PM
Real Name: Ron
Real Name: Ron
I see you have an '04, I did my '03 a couple of years ago, the steering u-joint that is. It's a little bit of a pita, I finally had to put some heat to it to get it to break loose from the spline shaft.
11-16-2020, 12:04 AM
Real Name: Seth
Real Name: Seth
Thanks man, I'll give that a shot! I've got some PB laying around somewhere.
11-16-2020, 12:05 AM
Real Name: Seth
Real Name: Seth
Seems pretty inexpensive like $40 something to replace? It looks pretty rusty down there from the CO winters and such. I'm gonna spray it with some penetrant like
@ AuSeeker
recommended then go from there! Thanks for your input!!
11-16-2020, 02:29 PM
11-16-2020, 04:43 PM
That is exactly how mine was. As mentioned, soak the steering shaft u-joint with penetrant. It will loosen up but the damage is done and it will become loose in a few months. I installed one from e-bay, cheap to buy but a pain to replace and get lined up.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
11-16-2020, 07:50 PM
Real Name: Skip
Real Name: Skip
@ AuSeeker
Originally Posted by Bossman
As Bossman mentioned the shaft is not cheap...not $40....but can be found for between $125 or so up to $200+.
McGeorge Toyota....
2003-2009 Toyota Lower Shaft 45203-35310 | Toyota Parts
Better deals if you do eBay....
Part Number: 4520335310 - Bing
2004 Limited V8
11-17-2020, 04:16 AM
Real Name: Seth
Real Name: Seth
Thanks for everyone's input!!! Since my rig is kind of worn out, not super keen on blowing lots on OEM stuff. I mean, for suspension, engine, trans, and 4x4 stuff I'll do OEM, but for this I'll probably do the Amazon thing.
Amazon.com: Tecoom 45203-35310 Lower Intermediate Steering Shaft Assembly Steering Column w/U-Joint Fit for 03-09 Toyota 4Runner: Automotive
The thing is probably going to get parked pretty darned soon and used only for crazy bad weather/offroad camping trips.
11-17-2020, 04:18 AM
Real Name: Seth
Real Name: Seth
First things first tho! Penetrant, here we come!
01-10-2021, 09:28 AM
has anyone experienced issues using the amazon or ebay parts vs OEM parts $35 vs $220 is significant, Job looks like a pain, some rust and limited access.
01-10-2021, 10:51 AM
For me, there are three factors that decide OEM vs whatever brand:
1) How hard is the job? If it takes 30 hours to do, I don't want to risk the part breaking and costing me another 30 hours.
2) Is there a critical safety issue with it breaking? Example: my sway bar endlinks I'm building, if they break, it will not be fun driving home, but I won't be stranded and I'm unlikely to end up in a ditch as a result.
3) Is there a performance penalty to non-OEM? Example: CV axles. While Napa axles work, they tend to bind at full droop. For me that's a major issue.
In this case, both 1 and 2 are relevant. You are unlikely to have a steering lfailure that puts you in a ditch, so it is worth considering. However, how long is it going to take? Don't put the cheap part in unless you are willing to do it twice.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
01-10-2021, 06:16 PM
Real Name: Steven
Real Name: Steven
Do yourself a favor and get the yoke too. When I replaced my intermtant steering shaft I had to cut the yoke off. There are 3 bolts and those are probably corroded n place too. If I remember right they where 10mm.
Amazon.com: Dorman 425-476 Steering Shaft End Yoke for Select Lexus/Toyota Models: Automotive
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
wierd miss in 87
posigen |
Classic T4Rs |
0 |
02-18-2013 02:56 AM |
Wierd problem
Paul H. |
Classic T4Rs |
13 |
07-16-2011 03:18 AM |
Wierd vibrations
Tafty86 |
3rd gen T4Rs |
1 |
05-19-2011 01:47 AM |
wierd noise
joey_magnelli |
Off-Roading |
1 |
10-20-2006 12:48 AM |
Wierd noise
Toy-Yoda |
Problems & Warranty Issues |
2 |
08-22-2006 08:55 AM |
