Old 01-17-2022, 03:02 PM #16
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by originalg00kster View Post
Okay cool I currently have the stock front bumper as well. Thank you again for the tip. I messaged Matthew as well.
I realized this morning I have 2x passenger recovery points and I'll need a driver side.
Ohh yeah that's no good haha. Hopefully he gets back to you and makes it right
y=mx+b is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 03:43 PM #17
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
Their bumper tie in has an extra piece that bolts to the recovery point and to the front of the frame horn. I’m getting ready to build my True North bumper that just arrived the other day. I didn’t order the frame tie-ins. I’ll probably make my own out of some angle iron and 3/8” plate I was given.
True North Fabrication Hybrid Bumper-8062aa77-222f-493e-bf08-aaed3d991909-jpeg
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 04:00 PM #18
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
Haha I ended up messaging Mathew and also calling SRQ. They were quick to respond and will be sending me a driver side asap. I'll just have to ship the extra piece back to them. Thanks again for your help!
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 01-18-2022, 05:12 PM #19
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Well I've used mine to winch out of a mudhole now. Did great other than blowing the fuse inside the box on my winch and not knowing that was a thing. D'OH.
I've thought about grabbing these instead of the TNF recover points: Recovery Points For Lexus GX460 / GX470 / 4th And 5th Gen 4Runner / FJ Cruiser
Its a shame the options are as limited as the are for the 4th gen.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 01-28-2022, 04:25 PM #20
These are the pics I have of my TNF recovery points. If the ARB uses any of these holes, then I'd say its iffy. Although the rear holes are slotted perpendicular to the frame, so they may be able to sit on top of bracket utilizing these points
SRQ sent the other side for me and it arrived today. How many bolts on each side? 3 right? When I was under there the other day, I still couldn't figure out where to mount it. hahaha. I'll have to go under again and see.
07 SR5 4x4
Old 01-28-2022, 04:28 PM #21
NVM! I see where they go now. Did you remove your front sway bar? It seems to go in the same threads as the front sway bar bolt locations. Do you think I could run a sway bar with the front recovery mounts?
07 SR5 4x4
Old 01-28-2022, 04:43 PM #22
y=mx+b's Avatar
y=mx+b's Avatar
Yeah 2 on the sway bar, in the crossmember, and 1 little one up on the frame
Yes I'm running no sway bar up front, but I did put it back on for a state inspection with the recovery points installed. They actually work as a good sway bar spacer to get the arms at the right angle if you're lifted
Old 01-28-2022, 04:55 PM #23
Awesome. I at least know where they go now. Thank you for all the help and info!
07 SR5 4x4
Old 02-10-2022, 08:31 PM #24
Real Name: Matt
Real Name: Matt
Got mine all welded up this last weekend. I love how it turned out. Only issue I have, and I knew this going in, is the gap between the wings and the fender due to my body lift.
True North Fabrication Hybrid Bumper-c9d8ba62-0f39-44f8-a3f7-2d2e0bbe2607-jpg
Old 02-11-2022, 06:48 PM #25
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks has a spectacular aura about phatcheeks has a spectacular aura about phatcheeks has a spectacular aura about
phatcheeks's Avatar
I use those recovery points/tie ins with my ebay taco bumper. I feel safer if I need to winch or get recovered now.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 01-25-2023, 09:42 PM #26
Real Name: Matt
Real Name: Matt
I have a question for you regarding the install of your winch in your TNF bumper, more particular the metal A/C line. It looks like I need to bend the metal line up about an inch and a half and back several inches. Just wondering how you went about it. Did you just bend it to clear or did you have to move or modify the brackets too? I don’t have any problem with bending it I just want it to look clean and of course not break.
Any help is appreciated.
Also on a side note I did end up ordering the TNF recovery points with the frame tie-ins.
Old 01-26-2023, 10:35 AM #27
So initially I just bent the AC line back. This seemed to work, until I rubbed a hole in my AC line back where it crosses the bumper back towards the radiator...
Right way to do it is to disconnect the center bracket (the one the instructions have you cut) and bend the AC mounting brackets until the AC lines fit behind it. Then, if there is anywhere your AC lines are close to the bumper, get some rubber hose and jacket the line so vibrations don't wear through the metal.
Just wish I could find a reasonably priced rear bumper...
Old 01-26-2023, 11:21 AM #28
Real Name: Matt
Real Name: Matt
Thanks. I did drill out the spot welds and removed the center bracket entirely. I also bent the line and sleeved it with rubber where it passes behind the bottom left when I installed the bumper and after reading about the issue you had. Sounds like I’ll have to just carefully bend the entire line back from the pressure port on the right across to the left.
bumper , fabrication , hybrid , north , true
True North Rear Bumper and Tire Carrier Kryptoroxx 4th Gen T4Rs 15 05-11-2023 06:59 PM
Calling all True North Fabrication plate bumper and winch owners. brianjasinski2003 3rd gen T4Rs 6 09-26-2021 09:06 PM
SRQ / True North Fabrications DIY Front Bumper Kit SRQ-Runner 3rd gen T4Rs 119 06-04-2021 08:44 PM
Review: True North Fabrications Hybrid Bumper Kryptoroxx 3rd gen T4Rs 2 01-07-2019 10:40 AM
True North Fabrication Front Bumper Franky4ag 3rd gen T4Rs 9 03-27-2018 10:38 PM
