Old 11-18-2020, 07:52 AM #16
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Originally Posted by payeentbawlur View Post
I had the positive removed. Should I have had both positive and negative wires disconnected?
Not trying to nitpick here but you should always disconnect the negative if you're only removing one cable. And when replacing a battery or removing both cables for any reason it's better to remove the negative first and connect it last. This is for other reasons and has nothing to do with the problem you're having.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 11:58 AM #17
payeentbawlur's Avatar
payeentbawlur payeentbawlur is offline
payeentbawlur is on a distinguished road
Originally Posted by 95supra View Post
I would try jump starting it again but instead of connecting the negative terminal to the 4runners battery post, connect it to a good solid metal engine part. the issue could be a bad engine ground and if you connect the negative jump lead to the actual engine, this will complete the circuit and the starter will turn.
give that a shot if you haven't already.
I tried it out this morning. Same result. Still pointing to the battery. Waiting for my girlfriend to be ready to be the key lady and try the other suggestions out. I appreciate the wisdom!
payeentbawlur is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 12:03 PM #18
I did a little research on this and I believe I understand(ish) why: So that there is minimal chance of my body conducting the current of electricity, or some gadget completing the circuit and exploding?
And I appreciate you chiming in. I am trying to understand as best as I can and want to be safe and intelligent when working, to the best of my ability. Electricity is something that I don't fully comprehend, but I'm making progress.
Old 11-18-2020, 01:10 PM #19
Tomm- Tomm- is offline
Tomm- is on a distinguished road
I'd pull your battery out and take it to to an auto parts store and have them tell how much CCAs its outputing (as well as voltage). They also do charging there too (for free) but if you have a bad cell nothing will help it. Sometimes batteries can still show good voltage but struggle with cold cranking amps. Any parts store will do the test for free and be happy to tell you why you need to buy a new battery. lol
2004 4Runner Sport V8
ARB - AUXBeam - Bilstein - Cali Raised - Camburg - CBI Offroad - Dobinsons - Factor 55 - Fat Bob's Garage - Maxtrax - Method Racing - OME - Prinsu Design Studios - Remark - Rotopax - Smittybilt - Traveler - Yokohama
2009 Ford F-150 Platinum
2013 Scion FR-S
Tomm- is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 02:07 PM #20
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
@payeentbawlur
Try disconnecting both battery terminals. Then touch the two to each other for few minutes.
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
V8Man is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 02:08 PM #21
V8Man's Avatar
V8Man's Avatar
@payeentbawlur
Old 11-18-2020, 05:26 PM #22
hankd's Avatar
hankd hankd is offline
Real Name: Harry
hankd is on a distinguished road
hankd's Avatar
Real Name: Harry
i'm one of the people that fried my computer on a deep water run. when the computer was damaged i didn't have any click from the starter, and also if you plug in a scan tool it won't recognize the computer. i know you've moved beyond this but thought i'd mention it anyway.
hankd is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 05:26 PM #23
MikeinNH67's Avatar
MikeinNH67's Avatar
Not so much your body as low voltage is not a big deal but wrenches, metal watches and such are the issue. It's just safer pulling the negative side to break the circuit.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 11-18-2020, 09:21 PM #24
Well, you were absolutely correct.
As were most of the responses in this thread. Took the battery to Advance and they tested it: All the cells in the battery were shot, 10 volts, and literally 0 CCA. So, as you can imagine, I got a new battery. Sort of a relief to be honest, at least knowing what the issue was/is. I do feel a bit silly for going on the initial wild goose chase and talked to my Dad about it and he said he was not aware you could have a battery full of voltage but have no cranking amps. So, we both learned a little bit today.
Put the new battery in 10 minutes ago. She started up like brand new.
So thank you gentle sirs! I very much appreciate every response and wisdom this forum has offered me. I should have just posted on here in the first place!
Okay okay, I will definitely start practicing this. Thank you for the response, just trying to soak in as much knowledge as I can right now.
Old 11-18-2020, 10:45 PM #25
MikeinNH67's Avatar
MikeinNH67's Avatar
Doesn't happen often but as you can see it does happen. The headlight trick tells all for that issue. Glad to hear it's fixed.
Mike
03 4runner Limited
Old 11-19-2020, 06:01 AM #26
Glad you figured it out! It's not very common, but having worked at an autoparts store (and done the battery testing more times than I can count) I have seen it happen before.
2013 Scion FR-S
Old 11-19-2020, 10:18 AM #27
Real Name: Danny
Real Name: Danny
The main reason is that if you have your wrench on the positive and it touches anything metal it will ground out and at the very least create sparks. In a worse case it could totally short out your battery and cause it to explode. On the other hand, if your wrench is on the negative terminal it can touch pretty much anything except the positive terminal, (or some random positive wire.)
Old 12-13-2020, 01:56 PM #28
Captsolo Captsolo is offline
Captsolo will become famous soon enough
So last weekend I did some much needed repairs on my frame on the passenger rail mainly near the transmission crossmember.
After the repairs were done the old girl started up with a little help from a jump (thanks to the battery being unplugged for long hours-days at a time) and she ran fine.
Started her up probably 3 or 4 times with no real issue. Then the last night the battery was a bit low so I trickle charged it overnight.
The next day, when trying to turn it over, all I get are hard clicks. No attempt at turning over at all.
CLICK-CLICK-CLICK-CLICK-CLICK
So my Dad and I figure starter is shot, as it had been making strange noises up until that point anyways.
I get a new starter and install it.
Same problem.
So I do some research and think maybe I have a bad ground somewhere (could still be the issue I suppose) and I actually found one that looked sketchy on the frame right below the battery. I take that off and clean up everything and replace that.
Same problem.
We've tried jumping it and that doesn't change anything either.
I've checked probably a dozen threads on starter issues and mainly see people saying the battery as the culprit, but no one has had my set of symptoms. All the others have been from deep water runs.
So, does anyone have a logical next step for me to take? I don't really want to take it to my mechanic and pay for hours of bad ground searching if it can be mitigated otherwise. I'm very new to all this. But thanks to this 4runner I am learning how to fix nearly everything on a vehicle, for better or worse.
Any and all help is very appreciated. I've looked for hours on the internet with no real true direction to head next. If anything needs clearing up, please ask!
I've had to replace three starters in my 2005 4runner (150,000) miles. Two bolts to take off. Had my mechanic do it.
On mine they would just quit after 4 years. No click, no nothing. Only issue with 4runner in 15 years. OEM WP, radiator, alternator, brake MS; 1 caliper,
Starters are cheap at Amazon for the 4runner.
I have a brand new back up in the garage because I expect another failure,
It will be 4 years on the one in this car in February.
I live in the Bahamas. Lot more starts than in Miami on a car.
Drive Train is as good as new. That's what I like about 4runners.
GM's don't last.
I think I will get to 500,000 miles on my Toyota.
garaged
coolant level is always the same level in the overflow canister.
Starts up the same as 15 years ago!
burns no oil.
leaks a drop of oil a week (just leave it).
No synthetic / stick with conventional
paint is like original - no chips or fading
I wonder if your alternator isn't charging the battery adequately.
I bought a cheap $50 alternator battery tester that reads out in words if alternator or battery needs replacing.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Captsolo is offline   Reply With QuoteReply With Quote
battery , frame , issue , real , starter
Front Cross Frame Peice Rusted... Welding? BigMike18 4th Gen T4Rs 9 08-13-2019 02:21 AM
Welding on the Frame plcfcng 3rd gen T4Rs 3 05-09-2019 09:34 PM
Tips for welding? Mostly safety First time welding a truck frame shahsmerdis 3rd gen T4Rs 31 02-14-2017 11:38 AM
Protecting frame after welding 4racer 3rd gen T4Rs 3 05-11-2016 07:34 PM
Rec for a frame welding job. Ulysses Maryland / Virginia / WV / D.C. 0 07-25-2011 10:30 PM
